Replaced cam/crank sensors, didn't help - Nissan Forums : Nissan Forum
post #1 of 7 Old 10-14-2012, 03:18 PM Thread Starter
I have a 2.5L altima with 82,000 miles. Common problem, 0335 and 0725 codes came on, symptoms are a hard start and quick engine revving on the highway.
I bought two Duralast SU6364 sensors and replaced the original OEM crankshaft and camshaft sensors.
From what I've read it seems that this fixes the problem immediately. In my case it didn't, and the same symptoms still persist.
I also tried removing the air filter, and checking to see if that little hot wire anemometer that senses air flow was dirty. It wasn't. Doesn't seem like an airflow problem causing it.
I don't know what else to check. I also can not get the connector off of the new crankshaft sensor because of the way it is now rotated 180 degrees (thinking maybe it was a bad brand new sensor).
nataddrho is offline
post #2 of 7 Old 10-15-2012, 07:22 PM
Emeraldalt3's Avatar
Quoted: 1 Post(s)
Which sensor did u get? The redesigned once, with the aluminum casting or plastic?
Sent from my Autoguide iPhone app
Emeraldalt3 is offline
post #3 of 7 Old 10-15-2012, 07:24 PM
Quoted: 1 Post(s)
Plus u might want to check your spark plugs.
post #4 of 7 Old 10-15-2012, 10:40 PM Thread Starter
Metal casing.
I don't think the spark plugs are causing the problem.
post #5 of 7 Old 10-19-2012, 06:08 AM
Make sure you clear the codes and disconect the battery terminas to reset the ecu, I would install nissan sensors, i dont trust anything alse, if its not the sensors it might be stretched timing chain.
2013 Infiniti M35h
62000 miles
2013 Altima 2.5S
67777 miles
Nissan remote start
Nissan fog lights
Altima coupe 18" wheels
Victory Cross County 8ball
Chlebek is offline
post #6 of 7 Old 10-25-2012, 09:08 PM
howd u get the first one off???? i used 2003 Nissan Altima S - Camshaft & Crankshaft Position Sensors - YouTube
i can touch it but cant seem to position my hands to get a screw driver in there to snap it off or to take out the bolt and then remove the connector..... pepboys wants 180 to do it... i feel like im so close... i dont wanna pay em!!!
my car is vibrating bad while i drive and worse at idle... motor mounts arent bad. spark plugs were recently changed as were the throttle body assembly, alternator, cam shaft sensor and both o2 sensors. process of elimination got me to the crankshaft sensor.
meestadeuce is offline
post #7 of 7 Old 10-30-2012, 12:30 AM
Quoted: 2 Post(s)
I think I know what your problem is, it might be your MAF sensor what you need to do is crank your car up and as soon as it starts unplug the sensor, if you notice any acceleration we hit the jackpot if not then keep on trying...
-Just a suggestion, even tho the wire looks clean(MAF) it might be sending the wrong signal to the ecu, give it a try...
Good luck!!
Ricooo is offline
