Not necessarily true. The main reason for high compression AND boost is so that there isnt ANY turbo lag. High compression allows the engine to be ultra responsive...Low boost is a must here as youve stated. This is a fine line, and if done correctly you will have a very nice set up, but understand me, when it comes to high boost, lots of variables here, a high compression build with a low boost application is not going to make as much as a purpose built low compression engine. Boost is relative to the size of the compressor used in the application, not the boost setting. With the VQ35 you could build a low compression build and with the right turbine AR, boost with enough pressure to flow enough air to generate 700+hp. This will not happen with a high compression build. You will detonate long before you reach the same levels. Sure you could build a 300-maybe 400hp high compression build, but it will cost a great deal more to do so....Many more variables I didnt account for, so this is just a quick vague, BUT true answer.
Originally Posted by 336se-r
Always very helpful. Yea I figured I did not need "race gas" I thought I read that the 370z have 11. Cr...
I don't want my car too b slow lol I'm at 268 whp and I dnt want to loose it by changing to 8.8 so I was thinking 11. And 75 shot on tune would b nice
Not a pro tho so please correct me if I am miss led lol
Also read that I could go high compression and if I decided to boost I cold run low boost and still make as much power as low cr and high boost
