Strange Humming Noise Coming from the Back of My car - Nissan Forums : Nissan Forum
post #1 of 12 Old 02-03-2013, 02:22 AM Thread Starter
Proud SE-R Owner
So for about a year now, maybe more I am hearing a constant humming noise coming from the back of my 03 Altima 2.5 S. For the longest time I thought it was the wheel hub assembly which is what a lot of people told me, as well as my own research I had found online
So I purchase a new wheel hub assembly for the left rear wheel, have my best friend (certified mechanic) replace it and STILL have this humming noise
It becomes audible around 40 mph, gets loud around 45, fades away from 45-55 and then at 60 mph it reaches its peak loudness before fading away to a low pitched almost inaudible hum at speeds of 65. I travel the highways here in Orlando at about 70 mph usually and don't hear anything
We (mechanic friend and I) determined it was the left wheel bearing hub assembly because thats where the sound is most audible when you sit in the rear passenger seats.
So we misdiagnosed. My mechanic friend dismissed it as road noise afterwards, but now Im out $120 ($60 for the part, and $60 to pay my friend)
My 03 Altima 2.5 S is now at 125k, and even though I plan to sell it in roughly 8-10 months, does anybody know what could be causing this noise?
SE-R_In_Orlando is offline
post #2 of 12 Old 02-03-2013, 04:15 AM
Quoted: 2 Post(s)
I have had the same problem for 5 months, no solution yet though. Let me know if you figure it out
Drew3.5Alti is offline
post #3 of 12 Old 02-03-2013, 04:55 AM Thread Starter
Proud SE-R Owner
I heard it may have something to do with brakes, but not sure how though. Any help would be great
2006 Altima SE-R
Nismo Cold Air Intake
HID Projector Headlights
post #4 of 12 Old 02-03-2013, 05:24 AM
i have had the same exact problem. But for me the sound is coming from the right rather then the left. Ive just gotten used to it and dont plan on spending the time and money to figure it out. I really only hear it on the freeway.
tacoshack is offline
post #5 of 12 Old 02-03-2013, 03:38 PM
edjose17's Avatar
THat happened to my car. I tought the noise came from the right side. Changed the right rear wheel hub and the noise was still there, although not as loud as before.
Problem went away when I replaced the left side rear wheel hub.
In my case it lools like they went bad both at the same time.
EdJose
edjose17 is offline
post #6 of 12 Old 02-03-2013, 05:01 PM
Super Moderator
4DZC's Avatar
Quoted: 374 Post(s)
iTrader: 33 reviews
Its the wheel bearing in one or both of the hubs.
4DZC is offline
post #7 of 12 Old 02-03-2013, 05:25 PM
Quoted: 5 Post(s)
A few things I can think of. My dad had the same problem recently on his car, I replaced both of his rear hubs. Both actually were bad, the noise was reduced a good amount but didnt go away fully. Then after that we had the feeling the tires were making the noise as well. A lil later he put on new tires, and the noise was 95% gone, so the tires are also a possible cause. A lil FYI on parts though, just cause they are new does not mean they are good, I can recally plenty of times a new part was bad so keep that in mind. Especially cheap replacement parts!!
2009 Altima coupe 2.5 6spd; my babe!
Amsoil synthetics, LED lights, illuminated kickplates, WC Lathewerks shift knob, Racing Line STS/TB kit/strut bar/RSB/ front & rear end links/ first 4th gen 2.5 with racing Line springs, first 4th gen to swap 7th gen maxima brakes (on 16" wheels).
-Plans for now/future:restored old school wheels in progress/ quad projector retrofit in progress.
Best 1/4 mile; 15.598@88.3MPH factory stock to the tires.
DD/work ride; 2000 Nissan Xterra 4WD V6 5spd
-Damn thing has a taste for blood and all my time, bringing him back to life= taking my money
Wade01 is offline
post #8 of 12 Old 02-04-2013, 01:32 PM
Quoted: 2 Post(s)
hey the best solution i have found is to turn the nob on your radio clockwise until it stops
post #9 of 12 Old 02-05-2013, 04:19 AM Thread Starter
Proud SE-R Owner
Hahah, my mechanic friend said the same thing
2006 Altima SE-R
post #10 of 12 Old 02-05-2013, 11:55 PM
Quoted: 2 Post(s)
Haha thats just the cheap way! I would definitely replace my hub assembly(s) if i knew thats whats causing the noise in my car. But im mot certain, so im letting it go for now. Does anyone know if it leads to other problems or if its just road noise?
post #11 of 12 Old 02-06-2013, 01:11 AM
saywat?'s Avatar
Quoted: 22 Post(s)
ugh maybe its the right side?
"Sorry Gramps, My Altima's Nicer Than Yours"
"I would like to apologize in advance for being brutally honest!"
MODS:
- Cargo Net retrofitted in the trunk
- 10w HID Converted Dome Lamp
- 8w HID Converted Door Lamps
- Removed OEM FogLight Covers
- Relocated "Special Edition" badge
- Custom Floor Mats with visible "Special Edition" Logo
saywat? is offline
post #12 of 12 Old 02-18-2013, 02:32 AM
Quoted: 2 Post(s)
wheel hubs. It will roar at any speed and consisten at highway speed. Ride like that long enough and it will put uneven wear on your tires and that will add to it. If ones bad the other should be replaced also.
Mine were so bad you couldnt have a conversation riding down the highway and the vibration was felt all the way to my seat. Wider tires on a car will shorten the life of a bearing alot faster. i was running 235 45's
keep riding with the stereo blasting and when your hub locks up going 70 miles and hour let me know if your radio is still working. lol
4ftswells is offline
