I have a 2006 Altima 2.5, just yesterday my pw, pl, power seats stoped working. First thing I check is fuses, dont find any problems but after I put 1 fuse back it started to work again then stopped. Looked under the hook because the manual states the 50/30/30 fuselink under the hood controls the pw.. I pull it, looks fine so I put a tester on both sides to make sure it has power, all is good then all the sudden the pl start working, thought I got lucky when to turn on the motor to try the windows dead again, all of them. So I finally figured out if I pull that fuse put it back in, and this is intermintent they will all work, but as soon as I move the key they die again. Is there a relay or something I Need to look at? I'm totally stumped by this, any help is appreciated.
Thanks
Thanks
