05 2.5 not getting power after new motor! - Nissan Forums : Nissan Forum
 1Likes
  • 1 Post By d0ugmac1
post #1 of 3 Old 05-18-2017, 10:55 PM Thread Starter
So I just installed a used 2.0 motor from JDM motors. Got all sensors plugged in, car didn't have any fuses under the dash inside so found a fuse diagram and installed the proper amp fuses. The starter seemed to be fine before the motor swap but it's not getting power to engage the fly wheel for some reason. Battery tested positive, and solenoid spins when I touch the post with a screwdriver but it doesn't engage the flywheel. When I turn the key everything in the car gets power and the dash light goes off as it should when i switch key to start but nothing. No clicks, no crank, nada. I am getting a faint click from the ignition or starter relay in the IPDM box but I'm not sure if that's normal or if it was clicking before. Any help would be greatly appreciative
Kendrick Addison is offline
post #2 of 3 Old 05-19-2017, 02:09 AM
d0ugmac1's Avatar
Quoted: 667 Post(s)
Did you reconnect the battery -ve cable to the tranny housing?
Do the headlights dim significantly when you try to start?
Kendrick Addison likes this.
Nissan OEM HIDs with Morimoto bulbs/harness, RacingLine FStB & RSwB @ 200%, ETI LED Fogs,
Altima FSMs & Useful posts: Bose Upgrade / Alternator / Bad Ground / Rear Brakes / TPMS Reset /
/ Spurious ABS / Audio Power / ABS Diag / Steering Lock / Lower VQ rad hose
d0ugmac1 is online now
post #3 of 3 Old 05-20-2017, 10:04 AM Thread Starter
I just double checked, battery cable is secured to trannybasbwell as the frame directly under the battery holder bracket
