WTF Rough Idle on my '02 - Nissan Forums : Nissan Forum
post #1 of 32 Old 09-26-2002, 02:20 AM Thread Starter
"More bounce"
Unhappy WTF Rough Idle on my '02
I'm alittle upset, I bought this car new, it already has a new engine in it and it has a rough idle now, what gives? I only have 5500 miles on it. The car runs fine it's just when I pull up to a stop the idle drops like it wants to shut off and it shakes a little at idle, has anyone had this problem? If so what was it. This is really starting to tick me off.
Pete2.5S is offline
post #2 of 32 Old 09-27-2002, 02:03 AM
Same thing on my 2.5S. When i come to a stop, my car tends to idle around 600 rmp. It also has a noticeable vibration and sometimes I mistake the engine noise for the sound of a diesel =) When i took the car into the dealer recently, the service manager said it should idle around 750 rmp. When I picked it up he said they had fixed my low idle problem, but it still does it. Does anyone know if it would it be possible to program the engine to idle at 800-900 rpm to improve acceleration times?
Beaker77 is offline
post #3 of 32 Old 09-27-2002, 02:06 AM
member
bring it back to the dealer and tell them to fix it right this time. I dout if they did anything the first time.
06 350Z
tytalian is offline
post #4 of 32 Old 09-27-2002, 02:10 AM
Haven't had that problem in my Altima. But in my old Camry the car would sometimes shut down after I got off the freeway and waited at a stoplight. I'd just restart the car and it'd be OK. Well, a few months later the transmission blew up ('91 w/ 200k miles) while I was on the freeway (smoke under the hood, RPM gauge going crazy, oil leaking, etc). So you should really get the transmission fixed or replaced soon before the car dies.
2002 Altima 3.5 SE Auto - Beige
Sologard Quantum Tint / Stillen Grille / 19x8.5 Enkei Aegis chrome 44mm offset / 245-40ZR 19 Dunlop Sport 9000 / Eibach Sportlines / Definitive MotorSports Underdrive Pulley / Magnaflow Muffler 14829 w/ larger piping and no resonator / Injen CAI / Stillen Front Lip / OEM Side Sills / Pioneer in-dash DVD player (AVH-P7480D) / Pioneer Navigation System (AVIC-90DVD) / Pioneer 12-disc CD changer (CDX-P1270) / Debadged / Two 2003 12" Kicker CompVR Subwoofers / Rockford Fosgate 301s 900 watt amp
http://www.altimas.net/registry/vehi...vehicleid=1016
Caliboy is offline
post #5 of 32 Old 09-27-2002, 02:30 AM
Re: WTF Rough Idle on my '02
Do you have any mods? When I tried putting a wai on my car it ran that way so I had to take it off.
see Altimate Derecho here
Barkos Motorsports Fresno, CA
(559)-456-4727 ask for Sako
Tell him Justin sent you.
justinhere is offline
post #6 of 32 Old 09-27-2002, 02:35 AM
boba addict
asher47's Avatar
same here - i have about 6k miles on my 2.5 and i'm noticing vibration at times, when i bring it in for the 7200mi checkup i'll let them know, only mod under the hood is a k&n
- johnson pang | asher
asher47 is offline
post #7 of 32 Old 09-27-2002, 02:55 AM Thread Starter
"More bounce"
Couldn't be the tranny I drive a five speed, no mods yet so it couldn't be that.
I do have a follow up though, the past few days I was noticing some other problems ie: coolant smell, sounded like I had a running water under the dash on a rev, rough idle and the car started to sound like a desiel.
This after noon on my way out to lunch I noticed a puddle of coolant under the engine, I took it straight to Nissan. They said they would let me know as soon as they finish looking at it. I will keep everyone posted. By the way I anlready had the engine replaced once for almost the same reasons.
Pete2.5S is offline
post #8 of 32 Old 09-27-2002, 03:06 AM
*Honorary Member* Bass&Style is all U need.
DeRaNgEd's Avatar
Quoted: 4 Post(s)
Do you use Mobil gas??????
I had a very similar problem in my Altima, the unoffical response from Nissan was not to use Mobil gas. Mobil os the highest alcohol content of any gasoline and Nissan motors don't like it.
Hope that helps.
REVEREND D: Eric is a maniac. You must understand this and accept it.
MADMIKE: Got beer jizzed on me and the GF courtsey of Eric
WarX: Eric is a freakin psycho
Taz: Eric you really are fucking crazy
PsyKoh: Eric's user name is so on the money
Makaveli24: u really earned the name deranged
Bigbird: The meets were only fun cause Eric gives awesome head and brings big tittied girls with him
DeRaNgEd is offline
post #9 of 32 Old 09-27-2002, 03:12 AM Thread Starter
"More bounce"
Re: Re: WTF Rough Idle on my '02
Hope that helps.
Really, I didn't know that I will try to avoid mobil. I don't use it religiosly but come to think about it the last time I filled up was with mobil. Has anyon else expierienced this with Mobil
Pete2.5S is offline
post #10 of 32 Old 09-27-2002, 03:19 AM
Lightning Shift 3.5
So whats the best brand gas?
V-Specin is offline
post #11 of 32 Old 09-27-2002, 03:57 AM
SE2002's Avatar
gas
The only thing that I have noticed is that at an idle, with all the accecories turned off (so that I can hear the engine, windows shut), from the inside it sounds like a diesel engine. Goes away if I increase the RPMs. I thought this was normal but I use exclusivley Exxon. Exxon and Mobile have medged, so it may be the same gas. I am switching to Chevron or Texaco to see if that gets rid of the diesel sound.
Mark
2005 Subaru OBXT Stage 1, TDC, 5EAT
SE2002 is offline
post #12 of 32 Old 09-27-2002, 05:38 AM
If you are talking about that ticking sound its the chain. Our motors don't use belts like most other cars.
Silver 2.5 Auto
Motegi, Khumo, Sportline, Active Tuning, HotShot
Alpine, Image Dynamics, Phoenix Gold
1greek4u is offline
post #13 of 32 Old 09-27-2002, 06:22 AM
There is a very simple solution to this..
I too have slightly rough idle on my maxima 3.5L as a result of low RPM idle (650rpms)..
Just go to nissan, asked to be hooked ujp to the CONSULT TOOL and bump the idle up by 100 or 200RPMS (your ECU is totally adjustable)..
Rough idle will go away completely..
ED
Edward Byon, B.Math
2k3 Maxima SE 6spd/HLSD/leather/chrome silver delivered 02/18/03
Frankencar intake with APEXi filter installed 02/19/03
35%/20% tint installed 02/21/03
LET THE MODDING BEGIN
2k2 Nissan Maxima SE 6speed/HLSD/leather package
RIP 01/30/03 on my B-Day
We miss you 2002!
- THE FIRST 2k2 with ADVANCED IGNITION
- 14.6 sec 1/4 @ 97MPH
- custom audio w/infinity, pioneer, hifonics, sony, rockford fosgate
- shaved emblems, tint, clear corners, and 30,000kms in 7months
1999 Nissan Maxima SE auto CDN - VLSD/auto climate/leather/gold letters/pearlwhite/BOSE crap
1996 Mazda Protege LX 1.8L 5speed -Compustar/magnaflow/infinity/ractive/unorthodox/earthquake/pioneer/nokia/ventshield/clutchmasters/touring wing/dark tint
RIP 05/15/02
My first tuner car, with 230,000kms till death
MiniRX7 is offline
post #14 of 32 Old 09-27-2002, 06:37 AM
Ruler of all 7 Eleven's
Hey miniRX7, hows your car running with the timing advance? I've been keeping up to date on your posts on Maxima.org
Check out my ride
Leading the war on non-search using idiots
And Exhaust Pics here
Slurppie is offline
post #15 of 32 Old 09-27-2002, 06:39 AM
Ahhh the power of Cheese
I dunno who told u bout that about mobil but thats bs. Gas is gas the only real difference is if a gas station waters down there gas or not. But i guess u gonna believe what u gonna believe. I only use Mobil, Exxon an Hess.
SharkDogZ is offline
