Procedure to reset Check Engine/SES Light - Nissan Forums : Nissan Forum
post #1 of 7 Old 04-24-2003, 07:00 PM Thread Starter
No, you can't drive it!
For anyone who needs it:
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Fully depress and release the accelerator pedal five times in less than five seconds.
4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the MIL light flashes.
5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
You can look up the trouble codes in the ESM/FSM; there's a bunch of them. In the ESM, refer to page EC-639.
Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
You can clear the code (and the annoying MIL) by holding down the accelerator pedal for more than 10 seconds while in Diagnostic Test Mode II. When you release the pedal, the ECM erases the trouble code(s).
Moderator please sticky.
3.5SE = My reward for 15 years of mini-vans!
My Polished Pewter beauty!
dadster is offline
post #2 of 7 Old 04-24-2003, 07:08 PM
Bad Boys are Back!!!
DesiEGO's Avatar
Thumbs up
Damn, pls tell me you did not invent this by yourself, that takes a lot of credit...........Awesome Job !
DesiEGO is offline
post #3 of 7 Old 04-24-2003, 07:27 PM Thread Starter
DesiEGO:
I wish I could come up with this on my own! As I run across stuff that works, I put it in a file and pull it out when needed.
I got this from nissan forums . com (remove spaces).
dadster is offline
post #4 of 7 Old 07-14-2009, 02:29 AM
h4x0r 1337
badboykillah's Avatar
wuts Diagnostic Test Mode II? i need to reset code
R.I.P 1990 Toyota Corolla DX
Tranny Blew to Exactly 3,910 pieces
Altima 2.5s 08
Dark Slate
http://www.youtube.com/watch?v=6HtxfDsuack
Modded Skyline SMOKES Bugatti Veyron
badboykillah is offline
post #5 of 7 Old 07-14-2009, 02:40 AM
That procedure is out of the factory service manual. There is also one like this to check DTCs for the automatic transmission, but I've tried it many times and never seems to work. Dadster ... have you tried the auto tranny procedure and made it work?
One hint here on this step. I found that if you did the 5 gas pedal depress and releases cycles as fast as possible (5 times in 3 seconds) that it seemed to work better.
Altima SSS is offline
post #6 of 7 Old 08-12-2009, 11:27 PM
MIL light
Is the MIL light you refer to the same as the Sevice Engine Soon Light? If not where is the MIL Light located. I tried to reset my SES light but haven't had any luck as of yet.
Thanks
Railroadman
Railroadman is offline
post #7 of 7 Old 08-12-2009, 11:50 PM
I'm so old school
wickedsr20's Avatar
iTrader: 7 reviews
Y'all do realize this thread is from 2003 right???
This is also covered in the FAQ (frequently asked questions) portion of the forum.
The key to resetting the SES is all in the timing. SES (Service Engine Soon) is the same as an MIL (Malfunction Indicator Light) and a CEL (Check Engine Light).
'03 Altima V6: totalled - R.I.P. - forever missed
07 Jeep GC SRT-8: debadged, Trufiber c/f hood, Volant CAI, Trinity, R1 rotors
Kenwood DNX9980HD - Audible Physics + US Amps being installed
wickedsr20 is offline
