P1273 Code - Nissan Forums : Nissan Forum
post #1 of 13 Old 08-10-2008, 12:34 AM Thread Starter
Inland Empire
Black SER's Avatar
P1273 Code
I'm getting about 3 SES codes total, but the main one i'm worried about is this P1273. I have the 100,000 mile warranty, but as many of you know I have a crap load of mods. And don't want to void the warranty due to some excuse about Intake and what not.
First off all what is this code? I searched and it says something about the A/F too lean or something to this nature. Also I noticed there was a post about a TSB.
Make : NISSAN Model : ALTIMA Year : 2005
Manufacturer : NISSAN NORTH AMERICA, INC.
Service Bulletin Num : 04090 Date of Bulletin: JUL 30, 2004
NHTSA Item Number: 10009365
Component: ELECTRICAL SYSTEM
Summary:
MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0300-P0306, P1273 OR P1283. *TT
Check to Request Research. Submit below
My car is running great so thats why i've delayed going to the dealer.
The other 2 codes i'm getting is a Transmission problem (5th gear stays stuck until a restart). I have to take care of these transmission problems, but don't want or need BS from the dealer saying My intake or Y-Pipe caused a sensor to go bad. So they can void the warranty. Your insight/diagnosis please.
Black SER is offline
post #2 of 13 Old 08-10-2008, 07:33 AM
Hey quick question, when ur tranny gets stuck in 5th, does it shift hard into R and into gear when you put it in drive??? because that shit happens to me also.
2006 Smoked Altima SE-R.
My CarDomain.
Current Mods:
Nismo Cold Air intake
Active Tuning Ground Kit
Nismo Oil Cap
Nismo Radiator Cap
Pioneer Avic-Z2
Mossy Cat-Back
Phenolic Thermal Intake Manifold Spacer Kit
CE Y-Pipe
Apexi SAFC Neo
Nitto Neo Gen 245/40/18.
Dyno Tune Nitrous Kit : 75 shot (wont stay that low long)
N.W.P. Engineering VIAS Block Plate Kit
Eclipse AVN726E
Focal Access all the way around.
Coming Soon:
BigDaddyOKC is offline
post #3 of 13 Old 08-11-2008, 01:51 AM Thread Starter
Inland Empire
Black SER's Avatar
To answer your question. YES! My tranny problem started just like your question you asked. And it's only going to get worst. You can expect tranny SES codes soon.
Anyone else?
post #4 of 13 Old 08-11-2008, 04:35 AM
well its been like that forever, and ****ing nissan did shit about it..... i even told em when my tps went out and they didnt do anything, i need to take it up there again.
My CarDomain.
Current Mods:
Nismo Oil Cap
Nismo Radiator Cap
Pioneer Avic-Z2
Mossy Cat-Back
CE Y-Pipe
Apexi SAFC Neo
Eclipse AVN726E
Coming Soon:
post #5 of 13 Old 08-11-2008, 02:37 PM
bSER272's Avatar
service manual says you should loosen then re-tighten the A/F sensor 1 (30-44 ft-lb). if problem persists, then try replacing it. It looks like its the one on the front exhaust manifold, so at least its easy access.
Other details:
Check the following.
 Harness connectors E21, F34
 IPDM E/R harness connector E122
 15A fuse
 Harness for open or short between A/F sensor 1 and fuse
>> Repair or replace harness or connectors.
good luck.
'05 Altima SE-R Super Black
Debadged | TEIN H Tech Springs (front)| Racingline Springs (rear) | UR Sc Pulley | Front MMI | AEM CAI | CE Downpipe | Mossy Cat-Back | AT Grounding Kit | AT S5 Grill | Axxtion STS | VIAS Mod | NWP Phenolic IM Spacers | IM P&P | Technosquare Reflash | Racingline FSTB | Racingline Rear Endlinks | Racingline HFPC
bSER272 is offline
post #6 of 13 Old 08-12-2008, 02:27 AM Thread Starter
Inland Empire
Black SER's Avatar
Took the car in and he said something about a CAT/heatshield problem. Seems like they are going to replace it. I'll have more info tomorrow and getting the tranny fixed.
I'll give codes and outcome tomorrow. But looks good. Just glad they didn't sweat me on the mods.
post #7 of 13 Old 08-13-2008, 05:36 AM Thread Starter
Inland Empire
Black SER's Avatar
Here are the codes that I pulled before I took car to dealer.
P0744
P1273
P0797
Heres what they did (typed on work-order)...
"Client states service engine soon light is on check and advise. Verified rear top catalytic converter shield has come off. The spot weld had broke off and has an exhaust leak code P1273. Removed and replaced catalyst and cleared code."
So supposebly there were no more codes and all is clear. When he called me I asked him about the other two codes, but according to him when he cleared the codes they never came back. Now I know i'm having tranny issues so I give him the benefit of the doubt.
I go to pick-up the car. I sign and pay because I got some other services done.
I get on the freeway and I noticed a bad shift. And knew the worst was about to come. Sure enough BAM! trip-tronic stays stuck in 5th and a SES light. I limp back to dealer and he says Let me guess. "The service engine light is back". We walk out I don't turn off the car so I can show him the trip-tronic is stuck in 5th. He's surprised and I get a rental.
I'm not sure if new codes became present when I got the car back from dealer, but
I'll keep you updated. Maybe this will solve alot of tranny questions you may have.
post #8 of 13 Old 08-16-2008, 05:49 PM Thread Starter
Inland Empire
Black SER's Avatar
All I can say is WOW!
Ok picked up the car yesterday and I got a new transmission. I popped hood open and I love seeing new stickers and a new heatshield. Big thanks to Sammy & Tony @ Corona Nissan. The service was great and had zero problems. I would highly recommend. So if your getting any of these codes. It looks like this may be your problem. Good Luck!
post #9 of 13 Old 08-18-2008, 08:46 PM
hey, mine is still like that but it has gotten worst, when im getting on it lets say im around 6k it drops down to like 4k then jumps right back up to 6k making my car jump like a bitch, but it has never thrown a ses for the tranny. gunna take it to my tuner shop to see if my neo could be causing the issue if it isnt then im going to nissan.
My CarDomain.
Current Mods:
Nismo Oil Cap
Nismo Radiator Cap
Pioneer Avic-Z2
Mossy Cat-Back
CE Y-Pipe
Apexi SAFC Neo
Eclipse AVN726E
Coming Soon:
post #10 of 13 Old 01-19-2011, 06:18 PM
First real post.... I seem to be having the same problem that you describe with the tranny getting stuck in 5th gear... and then after i cut it off and let it sit for a while then it goes back to normal. The first time this happend was last weds leaving work... and it just happend today again on the way to work... I work at a mazda dealership but my dealer also have a nissan dealership so i will be dropping it off tomorrow... glad i got a warranty and im hoping they do like your dealership did and just put in a new tranny... printing out this thread to show the people. Hopefully it wont be in the shop too long.
the only thing different is that im not getting any code or nor do i have any warning lights on dash? so am i just in the begining stages of this problem?
Bser is offline
post #11 of 13 Old 01-23-2011, 01:10 AM Thread Starter
Inland Empire
Black SER's Avatar
Glad I was able to help. Wow the good old days on this tranny stuff. I will be getting a drain/refill soon. It's not a DD, but i haven't had any tranny issues since the replacement. My buddy noticed he's getting tranny problems as i was. He states he doesn't have any codes either.
post #12 of 13 Old 09-07-2011, 02:52 AM
quickser4u619's Avatar
I have been having this (5th gear getting stuck problem) today. I left work and everything was fine and then the car got stuck in 5th gear. I couldn't downshift so i was driving from a dead stop in 5th gear which was pretty irritating. I parked my car and let it sit there after turning it off. I tried to start it, but it was having a difficult problem starting and it barely started. I attempted to put it into Reverse, and the car jerked kinda hard but not to hard. It did the same thing when I switched it to Drive after. I switched it to TIPTRONIC and it still said 5th gear... So I turned my car off.
I never had this problem before and do not know what it may be. Just like "Bser" said, I'm not getting any lights or codes of any sord, or at least did not get them when i was driving. I got a "Check engine Soon light" when i turned on my car but that's it.
I was going to get it towed to the dealer tomorrow and take it from there. My car reached 100k miles last friday and I have no warranty **** me lol.
Can anyone give suggestion or anything. Thank you
quickser4u619 is offline
post #13 of 13 Old 09-09-2011, 01:15 AM Thread Starter
Inland Empire
Black SER's Avatar
At first it would kick in....wait let me rephrase.It would slam in 5th gear hard without getting any SES codes. Trust me for all the guys that are getting stuck in 5th. It's a tranny problem that ends up in a tranny replacement.
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5) > 2005-2006 Nissan Altima SE-R Discussion
