Automatic Transmission Fluid Change? - Nissan Forums : Nissan Forum
post #1 of 54 Old 12-23-2008, 12:56 PM Thread Starter
Question Automatic Transmission Fluid Change?
What's up! I just bought a 05 Smoke SE-R with 54k on it. I paid $13,700 back in middle Nov. Felt pretty confident I got a good deal on it, but since it's used, I am not sure of some of the maintenance. I am about to change the oil to a full synthetic. Might try this Royal Purple stuff that I have been reading on the forums.
I guess the most important question relates to the transmission. Since the car has 54k on it, I am willing to bet the transmission has never been serviced. Anyone have any idea when to get this serviced? Is it better to get it drained and refilled or flushed? I've heard nightmares of people getting their tranny flushed and then shavings/debris cause problems, I think this is for higher mileage cars.
Someone help me out! Peace
jeffs3232 is offline
post #2 of 54 Old 12-23-2008, 05:25 PM
The VripMaster
jsut have them check the fluids, my 05 A/t ser 5spd have the K line of nissan fluid in it, and it's good to at least 96000km
CDXX is offline
post #3 of 54 Old 12-23-2008, 07:34 PM Thread Starter
So I am good for about another 6k. I will probably take it in to the dealer for a 60k mile service. Have them check everything out before the powertrain warranty runs out.
Anyone else have any opinions?
post #4 of 54 Old 12-24-2008, 05:33 PM
STL+SE-R's Avatar
Quoted: 1 Post(s)
If you're taking it to Nissan, just do what they suggest. I personally drain and fill myself. Oh, and even though its pretty pricey I would def get the Royal Purple for your next oil change.
STL+SE-R is offline
post #5 of 54 Old 01-29-2009, 02:19 PM
Brown Guy Black SE-R
SudZero's Avatar
When I had mine, I checked the fluid every 5000 miles or so....at the slightest dark tint i would change it...but i had a buddy that worked at nissan so i was gettin matic-k fluid for $5.25 a qt...and you're gonna need about 5-6 qts...nissan tried to sell me the bottles for $15 a qt...**** that...but lets just say my tranny was fresh all the time...54k is a little much...i would get that serviced ASAP because most likely the guy before you beat on it
2006 Altima SE-R 5AT Super Black (peaced out)
2008 VW Rabbit 6AT Candy White (NO MODS EVER! 36mpg)
SudZero is offline
post #6 of 54 Old 01-29-2009, 02:21 PM
SudZero's Avatar
Thumbs up
oh and in terms of oil...mobil 1 extended performance (good for 15k miles but i still changed it every 3k) was the shit in my se-r...never burned oil...always stayed healthy
SudZero is offline
post #7 of 54 Old 01-30-2009, 01:59 AM
I used the royal purple with Nissan filters doesn't burn any with 63k on her. I suggest just a drain and Fill with Amsoil Synthetic ATF. Do it 3 times to get a good mixture of new vs. old. Then change it every 20k or so just drop it once. It holds about 3.5 qts each time.
05 5AT Smoke SE-R
-Eibach Pro-kits
-Unorthodox SC pulley
-Stillen Intake(BLK)
-Stillen Exhaust
-2 Degree Advance
-Xenon 6000k Lows/Fogs
-Silverstar High
-Hawk Pads
-Eagle F1 GS-D3's
Smoked05SER is offline
post #8 of 54 Old 01-30-2009, 02:16 AM
Shift_matic
sentinal's Avatar
I highly recommend Amsoil too. I had a flush done at about 57k at the dealer ($75), just as maintanence. Tranny shifts nice and smooth.
_____________________________
Mods:JWT Popcharger, NWP VIAS & Spacers, 2º Timing Advance, Hawk HPS, over drilled RotorPros rotors,Techna-fit SS Lines, S5 clone grill< LED swapped gauges, CF interior trim, DDE's, footwell lights, 3K HID fogs THREAD HERE > Nitto Invo 245/40/18
Fluids: Amsoil ATF, Amsoil DOT3, Dist. H20+RL Water Wetter,Rotella T6 5w40, 93 Octane
Dyno231WHP/225WTQ <-youtube
sentinal is offline
post #9 of 54 Old 01-30-2009, 03:42 AM
2010 2.5s Sedan
jimnolimit's Avatar
welcome to the forum .
best bang for the buck motor oil in my opinion is pennzoil platinum , mobil1 extended life is also very good , amsoil is the best , but motor oil is your choice .
get your tranny oil flushed at nissan . only use nissan's tranny fluid !!!
MY AUTO BLOG (COMPLETE WITH INSTALLS).
http://jimsautoeverything.blogspot.com/
jimnolimit is offline
post #10 of 54 Old 01-30-2009, 03:46 AM
Originally Posted by jimnolimit View Post
get your tranny oil flushed at nissan . if you put any other tranny oil besides
nissan , you will have problems
Enlighten us.
05 5AT Smoke SE-R
-Eibach Pro-kits
-Stillen Exhaust
-2 Degree Advance
-Silverstar High
-Hawk Pads
-Eagle F1 GS-D3's
post #11 of 54 Old 01-30-2009, 04:06 AM
search you n00b!!!
pipeline's Avatar
did i hear Amsoil???
Originally Posted by altimatelyebony09 View Post
And damn those are some big rotor thingy magigies.
pipeline is offline
post #12 of 54 Old 01-30-2009, 04:07 AM
search you n00b!!!
pipeline's Avatar
EXPLAIN....
pipeline is offline
post #13 of 54 Old 01-30-2009, 04:07 AM
2010 2.5s Sedan
jimnolimit's Avatar
Originally Posted by Smoked05SER View Post
Enlighten us.
using any ATF besides nissan k-matic for the 5-speed auto is asking for trouble .
using non OEM nissan tranny fluid might cause the tranny to slip and/or to prematurely wear out .
nissan's tranny fluid is very good , you can't really "upgrade" by using aftermarket fluids . nissan owns JATCO which is a big transmission manufacturer and supplier (not only for nissan) , they make the transmissions so the fluid is specifically designed for them .
post #14 of 54 Old 01-30-2009, 04:10 AM
search you n00b!!!
pipeline's Avatar
using non OEM nissan tranny fluid might cause the tranny to slip and or prematurely wear out .
p.s. nissan's tranny fluid is very good , you can't "upgrade" by using aftermarket fluids . nissan owns JATCO which is a big transmission manufacturer and supplier (not only for nissan) , they make the transmissions so the fluid is specifically designed for them .
if the "other" fluid meets and exceeds OEM specs... why not use it??
and synthetic lasts longer and can take more abuse..??? am i wrong?
pipeline is offline
post #15 of 54 Old 01-30-2009, 04:11 AM
search you n00b!!!
pipeline's Avatar
btw... nice find... that is a good price
i bought mine used as well... i started changing out the fluids one by one.. that way i KNEW what was in there and how many miles i had to change them.. but that is just me...
pipeline is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5) > 2005-2006 Nissan Altima SE-R Discussion
