Who's had it done? How much did you pay for it? replacing my clutch, putting the stock clutch back in and the guy doing it for me just came and told that instead of $48 to resurface the flywheel it will be $180??? He keeps telling me it's because the flywheel is a double wall? Please excuse my ignorance I am not a mechanic by any means but those this make sense to any of you?
You may not be able to resurface the 3rd gen flywheel. I was previously told that you could not by the dealer.(note that dealers ussually will want you to pay for a replacement rather than do a resurface, there are also warranty issues involved).
If you have your own mechanic they may be able to resurface, but im not sure.
I did it with my Zcar. They usually cut or grind it. Cutting is usually done on a brake lathe. Just take it to a machine shop that has a brake lathe or a flywheel grinder. If a machine shop doesnt have this type of equipment, find one that does.
Injen CAI, Unorthodox crank pulley, VIAS delete, B&M short shifter, APR front strut bar, OBX headers, Straight pipe to Magnaflow mufflers, 60 shot when needed, Wilwood BBK, 8K HID's, NGK plugs.
Most of the time a dual mass flywheel cannot satisfactorily be resurfaced.
Majestic Blue '06 3.5SE, manual, 20% tint, blacked out window chrome, E-Bay grill, red calipers, wai, debadged, titanium pedals, resonator and crimp-gone. My other ride's an '03 Silverado 2500HD 8.1 liter monster. Previously had an 03 2.5S automatic.http://s115.photobucket.com/albums/n..._2006/?start=0
not true,...had new clutch put in...and my flywheel was resurfaced!!! no problems at all...if ur clutch was really bad and the rivots r touching the flywheel then its a no brainer...
A resurfaced flywheel is in actuality a bad practice, even if not a dual mass like we have. Anytime you remove metal from the flywheel, you are increasing the distance between the pressure plate and the flywheel, maybe even only microscopically. What this does with a self adjusting clutch, as in our case...hydraulic, you are removing a tiny amount of the usefullness of the clutch plate that is being installed. In other words, the new clutch may not last as long as the original did, simply because you are widening the gap between the pressure plate and flywheel surfaces, when the clutch is engaged. I hope you all see what I mean. In the real world, it may not make that much of a difference, but there is a difference. That is why I believe it best to go with a new flywheel and all other clutch parts upon replacement.
