Daytime running lights - Page 3 - Nissan Forums : Nissan Forum
  #31 (permalink)
Old 10-12-2011, 08:39 PM
G35dalf's Avatar
Brilliant and great find. Thanks a ton NismoAltimaGuy.
2007 Audi RS4 | 6 Speed | Premium Package | Sprint Blue | Nappa Silver Leather with Brushed Aluminum trim | 1,000W Pioneer sub, Kenwood amp | 255/30 R19
Gone but not forgotten: 2005 6SP SE R, Black on black with red inserts. RacingLine FTSB, 245/40 R18 tires
  #32 (permalink)
Old 10-13-2011, 04:28 AM
NismoAltimaGuy's Avatar
I hope it helped everyone else with this problem on here. Did it fix your DRLs?
© Smoke 2005 Altima 3.5 SE (5AT)
Σ NISMO Mufflers | RacingLine Performance HFPC, FSTB, Battery Tie Bar & Grounding Kit | Cattman Y-Pipe w/ HFC | VMS Racing Oil Catch-Can | NWP Spacers | Custom Injen AirBox | VIAS "P&P" | Enkei Raijin Rims | SE-R Front facelift | MTEC HID 6000K | RedlineTuning Hood Lifts | R1 Concepts Slotted Rotors | Posi-Quiet Ceramic Pads | Tint | Altima SS Step Plates | C-Mod Grille | Custom CF License Frame | 14.96 @ 93.45 MPH (Old: Cat-back only)
Δ Future Mods: Crank Pulley | Uprev tune | SE-R Tail lights
  #33 (permalink)
Old 10-14-2011, 03:03 AM
G35dalf's Avatar
I'm sure it will... I'll be checking it out this weekend and let you know.
  #34 (permalink)
Old 12-20-2011, 04:22 PM
Delirious's Avatar
Talking Thank you!
This worked for me, I had it working in just over 1hr time with these instructions.
My DRL originally was working intermittently but eventually it stopped working at all. When high beams were turned on just the right side light was working and the left non working high beam light bulb was good and had 10.8volts at the socket (not sure what is suppose to be there).
Thanks for this great writeup NismoAltimaGuy and would like to give credit the original author (at maxima.org?)
  #35 (permalink)
Old 01-02-2012, 09:35 PM
I believe this is the original post I saw on Maxima.org by maxximaa.
How to FIX your DRL - Maxima Forums
It didn't seem the photos were still available on that thread when I first saw it so I made my own for here.
  #36 (permalink)
Old 01-06-2012, 04:20 PM
G35dalf's Avatar
NismoAltimaGuy: thanks for the photos, directions and Max thread - it's a big help.
I will look at this as soon as the temperature gets above -20 round here (been putting it off too long).
  #37 (permalink)
Old 01-19-2012, 02:11 AM
So one burned out highbeam will cause the drl not to work? i just noticed one of my bulbs burned out and running lights did not work?
  #38 (permalink)
Old 01-19-2012, 02:14 AM
Yes.
03 Altima 3.5 SE 4AT
Berk V2 w/ Apexi ~ NWP VIAS Plate ~ Racingline FSTB, Grounding Kit, Battery Tie-down, Springs ~ KYB GR2's ~ UR Ultra Sc Pulley ~ BT Under hood and Trunk Lighting
  #39 (permalink)
Old 01-19-2012, 04:02 PM
So we changed the bulb on the drivers side and the new bulb still did not work? So assuming its the DRL box?
05 Altima 3.5 SE
  #40 (permalink)
Old 03-18-2012, 11:09 PM
My Altima hasn't had driving lights or the one high beam for a long time. Finally got around to checking the module.
Sure enough, all 3 of the solders were cracked, just like in your pics.
Five minutes of soldering and she works like new.
My thanks go out to you guys that figure this out, take the time to put up pictures and then post for others to use.
'05 2.5S Extra
  #41 (permalink)
Old 04-17-2012, 01:08 AM
Thank you so much for showing this tutorial, it helped me fix my high beam problem! I needed to get my car safetied and I thought i had no other options but to go to the "stealership". Thanks so much NismoAltimaGuy, you rock!
Now I just have to fix one of my low beams, I suspect it's a bulb issue.
I'll buy you a beer next time you're in Toronto!
  #42 (permalink)
Old 04-17-2012, 03:19 AM
Cheers!
  #43 (permalink)
Old 06-23-2012, 05:06 PM
Add me to the stats. My DRLs, and Driver side Highbeam stopped working this last Tuesday. My module is now on my kitchen table, just waiting for the Soldering Iron to make it here in the next 2 hrs. Can't wait to see if this is my issue too, as I have hair-line cracks at all three locations too. I'll let you guys know later... Thanks too...
  #44 (permalink)
Old 06-23-2012, 06:17 PM
Delirious's Avatar
This fix lasted me 6 months, now the DRL do not work at all
may be something else needs to be patched up on the module.
  #45 (permalink)
Old 06-24-2012, 03:33 AM
It'd be interesting to see if the issue now are the ones you fixed or new ones. So far it's been about 8 months and I have not had any problems with mine.
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5) > 2005-2006 Nissan Altima SE-R Discussion
