Daytime running lights - Nissan Forums : Nissan Forum
post #1 of 52 Old 06-17-2010, 01:03 AM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
Not sure if this applies only to Canadian drivers but I noticed mine are not working (even though it's 100% a Canadian car and it's the law to have them).
I've done no mods to any electrical or lights so I'm wondering if anyone else has had this problem. I didn't notice if they were working when I bought the car (used) over 2 years ago or if they stopped working somewhere along the way. I would imagine that if it's a blown fuse, more that just my daytime running lights would be affected.
Any ideas?
EDIT: everything (including lights), is working fine and the battery isn't low.
2007 Audi RS4 | 6 Speed | Premium Package | Sprint Blue | Nappa Silver Leather with Brushed Aluminum trim | 1,000W Pioneer sub & Kenwood amp | 255/30 R19 | 10mm wheel spacers | Flat Bottom Steering Wheel |
Audi RS4, 420 HP
8 piston brakes and engine from the Lambo Galardo
Sold in 2012 but not forgotten: 2005 6sp SE R, Black on black with red inserts. RacingLine FTSB, 245/40 R18
G35dalf is offline
post #2 of 52 Old 06-17-2010, 04:18 AM
Any ideas?
I had this happen last fall. I know you checked your lights but did you check your high beams (the DRLs are high beams at half power, as you may know)? If only one comes on, replace the bad bulb and your DRLs should come back on.
03 Altima 3.5 SE 4AT
Berk V2 w/ Apexi ~ NWP VIAS Plate ~ Racingline FSTB, Grounding Kit, Battery Tie-down, Springs ~ KYB GR2's ~ UR Ultra Sc Pulley ~ BT Under hood and Trunk Lighting
duaner is offline
post #3 of 52 Old 06-17-2010, 04:24 AM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
Seriously? If one high beam bulb goes, both DRL's are off? Didn't know that and I'll check the high beams tomorrow.
Thanks a bunch duaner - much appreciated, especially for the fast response.
Audi RS4, 420 HP
G35dalf is offline
post #4 of 52 Old 06-17-2010, 04:27 AM
You're welcome. Right place at the right time I guess.
I'd have to check the schematics to see how they did it but, yeah, that's the way they wired it up.
I suppose it's a nice way to know if a bulb is out rather than finding out at night on the highway.
duaner is offline
post #5 of 52 Old 06-17-2010, 04:40 AM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
Ya, right after I posted in the SER section I realized I posted in the wrong place...
For future searchers that come across this thread, here's a link to a nice step-by-step on how to change a bulb on the Altima:
Nissan Altima Headlight Bulb Replacement Guide With Pictures - PaulsTravelPictures.com
Audi RS4, 420 HP
G35dalf is offline
post #6 of 52 Old 06-17-2010, 06:01 AM
Inland Empire
Black SER's Avatar
was hoping for a tutorial on adding some....Oh well if you ever figure out the schematics let me know.
Black SER is offline
post #7 of 52 Old 06-17-2010, 06:56 PM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
Duaner, you were right. Driver's side is dead. Thanks for the great info bud.
Hey Black_SER, sorry dude, I'm no electrical engineer... lol. I do remember some threads about this - if you search the 2002 2006 Altima forum you may find something. Be advised there are number of components involved and a different harness than what's on a typical american car. GL.
Audi RS4, 420 HP
G35dalf is offline
post #8 of 52 Old 06-17-2010, 07:12 PM
You're welcome. Glad I could help.
Black SER,
As for wiring up DRL's, it looks like G35dalf is correct. Probably different/additional harnesses, a Daytime Light Control Unit, a switch for the parking brake, etc. I 'm not sure if anyone on here has tried it before or not. If you have the Service Manual, it shows quite a bit in there (that is all I'm looking at).
duaner is offline
post #9 of 52 Old 06-24-2010, 11:53 PM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
OK, replaced the driver's side high beam bulb today with a new one from the dealer, but it didn't work. The passenger side high beam does work. The daytime running lights are still not working as well.
I checked the wiring (as much as I could visually check) and I see no fraying or cuts to the wires and no evidence of parts rubbing against it. I've noticed no other electrical problems (no short) and the fuses are fine (I expected this since the passenger side is still working). The electrical harness for the bulb and connectors look clean (no dirt or anything like that)
I'm stumped. An easy bulb change has turned into a mystery...
Audi RS4, 420 HP
G35dalf is offline
post #10 of 52 Old 06-25-2010, 01:07 PM
Do you know how to use a multi-meter? If so, you should check for voltage at your headlight connector with the high beams on. That will tell you if you're getting power to your bulb or not. You might be one unlucky SOB who got a bad new bulb. Or you may have wiring problems farther up stream. If your main headlights are HID, make sure not to probe those contacts as they are going to be much higher voltage. I believe the high beams are just standard 12V halogen on our cars.
2005 Altima SER
Modifications:
Racingline Y-Pipe
swamper8 is offline
post #11 of 52 Old 06-26-2010, 06:27 AM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
Ya, didn't think of the multimeter - good idea. I'll check it out. The mains are HID and def don't want to mess with them. They are a completely different socket so there shouldn't be a problem of accidentally checking the wrong connectors, but if I don't return to this forum, you'll know what happened...
Audi RS4, 420 HP
G35dalf is offline
post #12 of 52 Old 06-26-2010, 03:11 PM
Altimer
Mike James's Avatar
Quoted: 68 Post(s)
Could be DRL module????
Altima traded for Odyssey
Current - 08 HIGHLANDER
Mike James is online now
post #13 of 52 Old 07-12-2010, 02:18 AM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
I'm starting to think the dealer gave me the wrong bulb (even though the socket was the proper fit). Anyone have the part number for the high-beams on the SER? (I presume it's the same on the SE?).
Audi RS4, 420 HP
G35dalf is offline
post #14 of 52 Old 07-12-2010, 03:46 AM
As far as I can tell, the high beam bulb is the same for all--9005 (HB3).
http://www.nissanclub.com/forums/f-q...eadlights.html
Neither the service manual nor owner's manual differentiate between 2.5, 3.5SE/SE-R bulbs for high beam.
Sucks that you haven't been able to get that going yet.
duaner is offline
post #15 of 52 Old 07-12-2010, 10:30 PM Thread Starter
G35dalf's Avatar
Quoted: 1 Post(s)
Thanks once again duaner. :-)
That's what I have - 9005 HB, 12 v, 65w.
Audi RS4, 420 HP
G35dalf is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5) > 2005-2006 Nissan Altima SE-R Discussion
