Odd sound from under the hood during low rpm acceleration - Nissan Forums : Nissan Forum
post #1 of 12 Old 07-25-2010, 06:51 PM Thread Starter
tsigeoff's Avatar
I'm getting, what seems to be some type of rattling sound, under the hood, in the low rpms during acceleration. I was almost sure it was a heat shield rattling or even a blown exhaust gasket leaking exhaust...that is really the only things I could compare the sound too. I went to my local exhaust shop and they found nothing wrong with the exhaust or gaskets. I checked my CAI to ensure it was nice and tight as well as the front bumper vents.
My buddy has an 05 altima se and he said his car makes the same sound and also has no clue what it is.
Any ideas or suggestions? I'm still under warranty and could take it to Nissan, but it's not affecting the performance and I'm hesitant to take the car there with the mods I have on it.
tsigeoff is offline
post #2 of 12 Old 07-25-2010, 08:13 PM
G35dalf's Avatar
Quoted: 1 Post(s)
I have the same sound. At first I thought it was a sucking sound from my CAI but then realized it's a rattling sound. It happens around 2,000 RPM in any gear, on acceleration. This only started happening a couple of months ago and I suspect it's from a loose heat shield but I haven't gone under my car to check it yet. I think if I do go underneath, I'm going to change out my y-pipe with a RL. I'll take the heat shield off at the same time.
EDIT see:
http://www.nissanclub.com/forums/200...ing-sound.html
2007 Audi RS4 | 6 Speed | Premium Package | Sprint Blue | Nappa Silver Leather with Brushed Aluminum trim | 1,000W Pioneer sub & Kenwood amp | 255/30 R19 | 10mm wheel spacers | Flat Bottom Steering Wheel |
Audi RS4, 420 HP
8 piston brakes and engine from the Lambo Galardo
Sold in 2012 but not forgotten: 2005 6sp SE R, Black on black with red inserts. RacingLine FTSB, 245/40 R18
G35dalf is offline
post #3 of 12 Old 07-25-2010, 09:35 PM
antispider
Oil could be low. Check it/change it.
2002 Black Nissan Altima 3.5 MT
>Technosquare ECU >SSIM >Injen CAI >Hot Shot Headers >Greddy Evo2 Catback
>JWT Clutch/Flywheel >Eibach Sportline >SE-R Tails
www.teamrev.net
cookaroo is offline
post #4 of 12 Old 07-25-2010, 10:13 PM
Majestic '06 3.5SE, 5 spd
froedrick's Avatar
Quoted: 1 Post(s)
Most likely heat shields. There are a crapload of them and they will rattle. I've had mine spot welded, but they're at it again. This time, they either come off or I may use a big hose clamp to keep them still.
Traded 10/10/11 for a 2012 Hyundai Genesis Track Coupe.
froedrick is offline
post #5 of 12 Old 07-28-2010, 08:36 AM
I had the shield around my exhaust's flex-pipe rust away to just two rings. The guys at maaco torched them off for free for me. I'd check there first, since you don't really even have to crawl under the car to see it.
mklueg is offline
post #6 of 12 Old 07-29-2010, 10:59 PM
Quoted: 4 Post(s)
got the exact same rattle, and it's pissing me off.
i checked the heat shield, but I need to get it on a lift to be sure.
defintely annoying as heck, though.
bgross88 is offline
post #7 of 12 Old 07-30-2010, 12:29 AM
G35dalf's Avatar
Quoted: 1 Post(s)
The good news is this is not a $1,800 engine tear-down to fix, as I had originally feared. Plus it gives me good reason to change out to a RL y-pipe.... :-)
Audi RS4, 420 HP
G35dalf is offline
post #8 of 12 Old 07-30-2010, 01:42 AM
Quoted: 3 Post(s)
im experiencing it also .. i have an 06 2.5 with 41000 miles .. it almost sounds like someone is shaking a can of paint for a couple of seconds and stops... any verdict on what it could be yet?
2.5alti06 is offline
post #9 of 12 Old 08-05-2010, 02:06 AM
CodeManVQ's Avatar
iTrader: 3 reviews
Are you all sure you're not pinging? That's usually the first thing I think when I hear rattling under load at low RPM.
CodeManVQ is offline
post #10 of 12 Old 08-05-2010, 09:17 PM
djboost's Avatar
had the exact same problem, took it to my exhaust shop said everything was fine drove it for about couple days and finally had enough of the annoying sound, jacked it up on the driveway and turns out it was my top heatshield around the area were the pipe comes down from the header near the Y pipe. not sure if that helps but good luck
djboost is offline
post #11 of 12 Old 08-09-2010, 11:22 PM Thread Starter
tsigeoff's Avatar
HAHAHAHAHAHAH no bullshit....I finally got around to jacking up the car and yep, the same exact heat shield was lose and rattling...we both need to find better exhaust shops LOL
tsigeoff is offline
post #12 of 12 Old 08-11-2010, 09:15 PM
djboost's Avatar
haha yeah i know, glad that worked out for you, it is quite the annoying sound lol.
djboost is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5) > 2005-2006 Nissan Altima SE-R Discussion
