P0780 code - help needed - Nissan Forums : Nissan Forum
post #1 of 4 Old 11-01-2011, 05:04 PM Thread Starter
Cyter's Avatar
I have an 06 auto Altima ser and haven't had any real issues... Today I was driving on the highway and the tranny kept slipping.... It threw an engine code (p0780) which from what I can tell is a shift malfunction code, has anyone ever got this problem?
2006 Altima SER / Nismo Exhaust / Racing Line Springs
Cyter is offline
post #2 of 4 Old 12-22-2011, 01:46 AM
I had the same code
My car was acting up before and after that code(it showed the code only for a couple of hours and then it disappeared). The worst was when I was making a turn and going back on the gas it would slam in gear, bad sometimes. I was having a hars downshift in a straight line also when it was a red light and wanted to stop. I ended up replacing the valve body and after that problem solved . The trans oil was normal when I had the problems. Hope this helps... Gl and hope u don't have to replace Anything since the trans service is expensive... Keep me posted if you figure it out.
costi is offline
post #3 of 4 Old 12-22-2011, 01:49 AM
P0780
PS : I have a 05 se-r , auto
costi is offline
post #4 of 4 Old 01-01-2012, 11:54 PM
4DR-350Z
Critical-Audio's Avatar
Quoted: 5 Post(s)
He is right^ its the valve body
Im having same problem with the solution on the way.
Part for the fix Transgo AW55-50SN
Read this Trans Fix 5spd Auto Maxima
FAST.... ....
Critical-Audio is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2002-2006 Nissan Altima Forums > 2002-2006 Nissan Altima Discussion (2.5 & 3.5) > 2005-2006 Nissan Altima SE-R Discussion
