2007 Altima 2.5 CVT--Code P0745? - Nissan Forums : Nissan Forum
post #1 of 10 Old 08-07-2007, 04:47 PM Thread Starter
I just replaced the engine in this car and am getting a code P0745 on the second restart. Did I forget to plug something in or do I have another problem? I spent the $75 for the CVT fluid and its full and doesn't seem to have any kind of problems driving but the light is on. Any input?
Thanks,
Craig
CARMandP is offline
post #2 of 10 Old 08-07-2007, 05:08 PM
Rub my fender
Foglght's Avatar
I'm confused. YOU replaced the engine?
Do I look like a cat to you boy? Am I jumpin' around all nimbly bimbly from tree to tree? Am I drinking milk from a saucer? DO YOU SEE ME EATING MICE?
Foglght is offline
post #3 of 10 Old 08-07-2007, 05:26 PM Thread Starter
Yes. The customer severely overheated the engine driving it with a known coolant leak and ruined the engine. He wrecked it and drove it 150 miles and kept adding coolant but still ruined the engine. The oil was a nice milkshake color and it smoked really bad. Car has 1600 miles and Nissan refused to help him because he did it to himself. So he got another engine and I replaced it for him. Not a bad job but I have a check engine light which I am not sure if its something I did or if it was there before.
I need someone to tell me if this is a sensor that I may have just left unplugged or if its something else.
Thanks,
Craig
CARMandP is offline
post #4 of 10 Old 08-07-2007, 05:51 PM
bgrose's Avatar
P0745 Pressure Control Solenoid Malfunction
Is the error that you received. You might want to check the Pressure Control Solenoid, with a new one and see if the code goes away. If it doesn't you got a pressure problem somewhere. If you don't want to try new take the Solenoid off of the one you took the motor out off and try that solenoid.
bgrose is offline
post #5 of 10 Old 08-07-2007, 06:14 PM
Rub my fender
Foglght's Avatar
It sounds like you might have left something unplugged. I suppose go find out where the solenoid is located (hopefully not inside the transmission). If it is not unplugged, I would look at a pinched harness or a pulled out pin. If it wasn't there before, it's more than likely something you did caused it.
Most of those 700 codes are for the transmission. If I knew what that solenoid actually did, I could help you more.
Good luck.
Foglght is offline
post #6 of 10 Old 08-07-2007, 06:34 PM
I take PayPal donations
DryHeat's Avatar
P0745 LINE PRESSURE SOLENOID VALVE
Description INFOID:0000000000991989
The pressure control solenoid valve A (line pressure solenoid valve) regulates the oil pump discharge pressure
to suit the driving condition in response to a signal sent from the TCM.
DTC Logic INFOID:0000000000991990
DTC DETECTION LOGIC
• This is an OBD-II self-diagnostic item.
• Diagnostic trouble code “P0745 L/PRESS SOL/CIRC” with CONSULT-III is detected under the following
conditions.
- TCM detects an improper voltage drop when it tries to operate the solenoid valve.
- When TCM compares target value with monitor value and detects an irregularity.
Possible Cause
• Harness or connectors
(Solenoid circuit is open or shorted.)
• Pressure control solenoid valve A (Line pressure solenoid valve)
'05 Altima SE-R
'09 Honda Odyssey EX-L w/RES
DryHeat is offline
post #7 of 10 Old 08-07-2007, 07:13 PM
Rub my fender
Foglght's Avatar
ok, unless the valve got gummed up when the coolant started mixing, sounds like a disconnected sensor.
Foglght is offline
post #8 of 10 Old 08-07-2007, 10:22 PM Thread Starter
Well, it was mixing the coolant and the engine oil not the CVT fluid. I am wondering where that solenoid is. I am figuring I left it loose just need to know where it is located if anyone can tell me.
At 1600 miles wouldn't think there was anything wrong with the solenoid.
Craig
CARMandP is offline
post #9 of 10 Old 08-07-2007, 11:29 PM
Dexion's Avatar
uugh, definitely steering away from anymore car's that have a QR25DE in it. (Of course I can't really complain since my 04 has given me no problems)
"knock on wood"
2004 2.5S 10/24/2006 -10/20/2007
2007 3.5SE 6-speed 10/20/2007~
Mods: Fujita WAI | DDM Tuning Slim 35W 6000K H11's | Nismo Catback exhaust | Racingline Y-pipe
Current track data: 60' 2.332 1/4 mile 14.276@100mph
4/24/2009
252fwhp & 230lb-ft torque - more accurate
Dexion is offline
post #10 of 10 Old 08-13-2007, 03:58 PM
I'll go ahead and steer away from drivers that knowingly drive an overheating engine more than 100'. Not a lot of stock engines are going to stand up to that treatment.
"knock on wood"
Matt H. is offline
