I finally figured out how to wire my fog lights. First of all I have an 08 2.5s with conv. package and it is pre wired for fogs, I got the fogs from Flea. I re wired it at the combination switch. Basically it works like stocks and you leave the fog switch on all the time, Fogs come on with the headlights, and go off when hi beams come on. Basically on pin connector M28 which is connected to the combo light switch in the steering column pin 2, ouput 4, wire color green/yellow becomes hot (+4v) when the headlight are on, this wire would feed the factory fog switch, pin 13, input 5, wire color red/yellow sends +4v from the fog switch to BCM telling it to turn on the fogs. What i did was cut the red/yellow wire going out from M28 and spliced it in to the green yellow wire, leaving the red/yellow wire on the connector hooked to nothing. By passing the factory switch that does not exist. I will add some pics when I find out how. It took about 3 hrs to figure out the wiring and about 10 min to actually do it. I was a little nervous when i'm messing around with the BCM.
The Following User Says Thank You to Altima Willy For This Useful Post:
Basically if you take the steering column covers off (3 screws) the connector is located on the bottom of the combo light switch. Cut the the red/yellow wire and spice the end going out from the switch into the green yellow wire. I have a couple of pics, if somebody could please let me know home to get them on I will post them. Don't worry I had a headache for 3 hrs trying to fuigure it out
ok just to clarify willy's point, when you open up the steering column, on the LEFT SIDE of the steering wheel there is a WHITE plug. That is the one to look for the wire color combinations (2 wires) that he's talking about. You will find SIMILAR color combinations if you look at the RIGHT side of the steering wheel, do not mess with those. I did by mistake and hooked up my highbeams and messed up some other wire :P. Anyways, the mod is a snap, took 5 minutes (if even) to take off the covers (you have to turn your car on to move the steering wheel to expose the two side screws), 2 minutes to get rid of general wire sheathing so I could see everything, and 2 minutes to do the splicing. Everything works GREAT.
Also, have handy rags to wipe off grease, they have it all over the steering column, and I got it all over my pants.
Thanks for all the hard work on this - so basically all you did was plug your fogs into the foglight wiring at the bumper and do this electicial splice at the steering column if I understand right. Did you add a fuse anywhere or does the pre-wiring to the bumper for the fogs have a fuse already?
Again thanks for figuring this all out - saves us all alot of time.
I can't find anymore lights on E-Bay from Flea - do you know if he still has some or have you heard anything back on Autopia Lighting Xenon White Fog Light Kit 2007-2008 for Altima? There price is around $50 but would rather have lighting from Flea as per your post seems to work really well.
Hey,
I have the autotopia lights from ebay wanna buy them off me for $40? They have not been installed on my car.
Many thanks after reading a lot of wasteful posts out there I finally got to see what wire to tap.
I will add that I did hook up the wiring to a manual fog switch that I slid between my traction control and trunk release buttons.
I chose to tap into that Red/yellow wire and then ground to the fuse panel.
