Damn tire pressure light - Nissan Forums : Nissan Forum
post #1 of 30 Old 10-21-2008, 08:55 PM Thread Starter
Won't go off. Anything I can do, or do I have to take this in? Checked my tire pressures and they're all 30+
CaseLogic is offline
post #2 of 30 Old 10-21-2008, 08:56 PM Thread Starter
well I can't delete this thread, so a mod can do it for me.
post #3 of 30 Old 10-22-2008, 12:15 AM
missouriguy1973's Avatar
Fill them up to 34-35 and it'll go off...Stock they should be at 32psi, 2-3psi won't hurt them and your light will go off...
2007 Precision Grey 3.5L SE with CVT
14.54@96.53mph, 2.29 60' bone stock
2007 Nissan Altima 3.5 SE CVT: 14.540 @ 96.530 MPH <----click here! The more clicks the better chance I have to win a GoPro!
missouriguy1973 is offline
post #4 of 30 Old 10-22-2008, 01:08 AM
Quoted: 3 Post(s)
Due to the recent cold weather, my TPMS light turned on. When I measured the tire pressure in the morning, before I left, it was 27 psig. After driving the car to work the pressure went up to 30 psig, however the light did not reset. Filled all of the tires with 34 pounds of air, drove the car above 15 mph, and the TPMS light turned off.
pmueller is online now
post #5 of 30 Old 10-22-2008, 03:34 AM
white6spd's Avatar
I havent had any problems with my due to the cold weather but my GF's sisters Kia Optima and my friends 04 Acura TL have been.
10 370Z Base+Spt 6MT: Fast Intentions Non-Resonated CBE, Stillen G3 CAI, Fast Intentions Non-Resonated Test Pipes, UpReved Tune, JDM Rear Fog.
339WHP 252WTQ
white6spd is offline
post #6 of 30 Old 10-22-2008, 01:36 PM
The Baltima
Nesh's Avatar
I hit a bump a while ago with my aftermarket wheels (still using the Nissan TMPS just reset by my wheel shop to work for my 40psi setting) and the light came on, i took it to two tire shop and they both made sure i was runnin 40psi. im guessing the sensor is damaged and with my aftermarket wheels, tires, suspension and rotors, Nissan Of Queens wont entertain the idea of replacing this or giving me a new sensor.
The Baltima: 2007 Nissan Altima 3.5SL CVT Navigation, Rear-View Camera, Factory-Option Spoiler.
20" Rennen E2 Chrome and Black Rims Wrapped in Falken FK452 245/35Z/20 Tires.
Black Injen SP Short Ram Intake w/Heat Shield.
Eibach Pro-Lowering Kit 1.4" Front, 1.0" Rear.
TriNET Cross Drilled and Slotted Rotors w/ Stillen Pads
Interior Strobes
Check Out My Cardomain and Leave me a Comment
Nesh is offline
post #7 of 30 Old 11-15-2008, 07:24 PM
pimppapa1977's Avatar
I'm having the same problem just had tires rotated n filled to 32 and still have it.I'm gonna fill to 35 ill keep u posted.
pimppapa1977 is offline
post #8 of 30 Old 11-16-2008, 06:07 PM
Quoted: 6 Post(s)
First thing I'd recomend is a new tire guage. there's a reason they only cost a couple bucks. I had the same problem with my car last year. It got cold, and the TPMS light came on. so I used my guage and measured it, and all the tires showed they were fine. so I went and got a new guage, and sure enough, three of the tires were about 7 psi low.
1998 nissan 200sx se (daily driver)
2007 nissan altima 2.5s cvt (wife/family car)
2012 chevy camaro (weekend toy)
jd10013 is offline
post #9 of 30 Old 11-16-2008, 08:40 PM
Just a reminder to , there's a Low Tire pressure alert from the TPMS and there's also a Tire Mainenance interval alert that is set to a specific mileage (changable by you) to remind the driver to rotate the tires . This maintenance alert is in the same MENU branch as the oil and filter alerts .
CanisLupus is offline
post #10 of 30 Old 11-16-2008, 09:37 PM
Vital's Avatar
Quoted: 7 Post(s)
iTrader: 11 reviews
How about a different kind of cookie:
When i tup my aftermarket rims on, i used tpm off stock wheels. I had to temporary put them back on today so off course i didn't take tpms off aftermarket, i just bought 2$ air vales at Autozone.
When stock hubcaps with stock rubber withOUT tpms were put back on i expect the light to turn on, but to my surprise it didn't!! i drove around for a while but it's still not on.
Vital is offline
post #11 of 30 Old 12-12-2008, 03:14 AM
DarthGanu's Avatar
Last Saturday, I had an oil change at Costco. I picked up my car after it was finished and everything was okay. Until the following morning, the TPMS light came on. I don't know why it came on when I know the tires aren't flat or anything. So I looked at my receipt and saw the PSI was at 29. Friggin' Costco oil change man reduced all my tires to 29 psi without even looking at the 33 psi cold pressure requirement on the door jam. So I stopped by my mechanic and put some air to reach 35 psi. TPMS light went off after I drove for about 5 miles.
2007 Altima SE with Sport Package in Radiant Silver bought in the US; 2000 Altima SE in Steel Metallic. "Yup! They're that good!"
DarthGanu is offline
post #12 of 30 Old 12-12-2008, 04:38 AM
i make cars go fast..
Quoted: 2 Post(s)
ok guys this is totally a newbie question, but i cannot for the life of me find where to check my PSI on the MID in the gauge.. help please?
2009 Super Black 2.5SL CVT Loaded
3.5 Mirror
8000K DDMTuning Lo
3000K DDMTuning Fog
Stillen Front Lip
K&N Drop-In Filter
Super Black Grille
Racingline White LED Kit
starzplacez is offline
post #13 of 30 Old 12-12-2008, 02:08 PM
xeene's Avatar
Quoted: 6 Post(s)
instrument panel won't tell you your psi, it'll only warn you if it's lower then it's supposed to be. if you want to know your psi, you need tire pressure measurement tool.
nissan factory shop manuals
xeene is offline
post #14 of 30 Old 12-12-2008, 04:21 PM
Dusko123's Avatar
This happend to me last week actually
I just filled them to 32 33 psi drove around for a while and it turned off
it said that it was going to turn off at a certain speed but
it didnt untill i drove around for like 15 mins
Dusko123 is offline
post #15 of 30 Old 12-18-2008, 09:27 PM
07 Hybrid, Getting 37 MPG
AmpHere's Avatar
Wow, this was timely, thanks for not deleting this thread. My TPMS light came on too, I pumped to 33 psi, obviously not enough to turn it off. Thanks for the info.
AmpHere is offline
