how often should we rotate tires? - Nissan Forums : Nissan Forum
post #1 of 16 Old 10-29-2008, 04:06 PM Thread Starter
Trek Rider
Erased By User
cosmotravis is offline
post #2 of 16 Old 10-29-2008, 04:07 PM
xeene's Avatar
Quoted: 6 Post(s)
every 5k miles.
nissan factory shop manuals
xeene is offline
post #3 of 16 Old 10-29-2008, 04:13 PM
just wondering why you don't read your owners manaul...
sodaks2k is offline
post #4 of 16 Old 10-29-2008, 04:14 PM
xeene's Avatar
Quoted: 6 Post(s)
most people don't.
xeene is offline
post #5 of 16 Old 10-29-2008, 04:20 PM
Originally Posted by cosmotravis View Post
should i tell them to do the x pattern or simply front to back?
probably in your owners manual too...
I do the x pattern.
sodaks2k is offline
post #6 of 16 Old 10-29-2008, 04:48 PM
Firday Misspeller
Foot2Floor's Avatar
Quoted: 1 Post(s)
Originally Posted by sodaks2k View Post
I just did yesterday, I'm good.
I do the x pattern.
I hope your tires don't have Arrows on them. Directional tires should stay on the same side. Just rotate front to rear.
In just two days from now,
Tomorrow will be yesterday.
Foot2Floor is offline
post #7 of 16 Old 10-29-2008, 05:03 PM
No I don't have directional tires. If you only do front to rear all the time, your tires don't get rotated properly.
sodaks2k is offline
post #8 of 16 Old 10-29-2008, 05:20 PM
hazmat's Avatar
The owners manual says front to back...not sure why.
I always use the modified X pattern as follows:
Regular and proper tire rotation promotes more uniform wear for all of the tires on a vehicle. All season tires should be rotated in a "modified X" pattern, meaning only the tires being moved to the drive axle are crossed to the opposite side of the vehicle.
The remaining two tires are moved from the drive axle to the free rolling axle, remaining on the same side of the vehicle. This method of rotation helps promote a more even and uniform treadwear pattern for all four tires.
The only exception to this would be the use of "directional" tread design tires such as our Aquatred II or some of our Eagle line high performance tires. These tires would remain on the same side of the vehicle and be rotated straight forward and straight back.
And I usually wait and rotate every 15k.
2008 2.5SL
Sonoma Sunset
2007 FX35
Autumn Copper
hazmat is offline
post #9 of 16 Old 10-29-2008, 06:10 PM
See ya
iTrader: 3 reviews
I do every 5k on my truck
Sassan is offline
post #10 of 16 Old 10-29-2008, 06:38 PM
Shaving My Shoulders
RIZAMAN's Avatar
Quoted: 276 Post(s)
I think I remember my manual saying 7,500, but I can't remember...
EDIT: Yep...
Of course things will differ...I have a 500 UTQG wear rating on my Yoko's...I did the 1st rotation with these @ 10K...
|2013 G37S|CURRENT|
|2005 3.5SE|TRADED |
Originally Posted by Penguinchit View Post
All you G owners suck balls.
RIZAMAN is offline
post #11 of 16 Old 10-29-2008, 09:42 PM
rotation
I just rotate mine whenever I can see a noticeable difference in the tread, I just go front to rear also.
ccmills is offline
post #12 of 16 Old 10-29-2008, 10:17 PM
missouriguy1973's Avatar
I do mine as per the manual, every 7500...
I just do mine front to back, with not criss cross because you aren't going to get that much more out of them with the criss cross if your car is in good alignment...Besides, have you ever tried to rotate tires with the criss cross only using a jack and jackstands? It's not that easy to do...
2007 Precision Grey 3.5L SE with CVT
14.54@96.53mph, 2.29 60' bone stock
2007 Nissan Altima 3.5 SE CVT: 14.540 @ 96.530 MPH <----click here! The more clicks the better chance I have to win a GoPro!
missouriguy1973 is offline
post #13 of 16 Old 10-29-2008, 10:55 PM
It's quite easy as that's what I use. Jack the front up, place jack stands. Jack the rear up, place jack stands. If you only have two jack stands, then leave the jack in place on the rear and swap the rears first. Not safe or ideal though.
sodaks2k is offline
post #14 of 16 Old 10-30-2008, 12:05 AM
Yeah, only 2 jackstands here...I don't trust having a car up on just a jack though...A buddies car I helped work on crashed down when his jack lost hydraulic pressure, and we were lucky that no one was under the car when it happened...
I guess 4 jackstands would be a good thing to have...
post #15 of 16 Old 10-30-2008, 12:57 AM
That's why I use four!
I got mine at harbor freight tools. Looks like you have two to choose from. I don't know that they're any cheaper than onther places, that's just where I got mine.
Harbor Freight Tools - Quality Tools at the Lowest Prices
sodaks2k is offline
