Auto window (up) not working - Nissan Forums : Nissan Forum
post #1 of 5 Old 11-05-2010, 02:32 AM Thread Starter
Hi,
I took out my door panel both the plastic part and inner panel to remove a dent in driver side. So the dent is not looking that bad right now, but when I reinstalled everything back I realized that Auto Window (up) for driver side is not working with one touch, although it is working when I hold it. What could have I done and how can I fix it? Everything else is working fine. Your help will be appreciated.
programmerboy is offline
post #2 of 5 Old 11-05-2010, 03:01 AM
krazzyborri
You have to re learn the switch. Anytime power is removed (or switch un plugged) the switch has to be re-learned..
Hold the window down switch (all the way) until the window is all the way down. continue holding for about 5 seconds. then pull switch all the way up until the window is rolled up. continue to hold for 5 sec. auto up/down should now work.
krazzyborri is offline
post #3 of 5 Old 11-05-2010, 03:01 AM
Boomer
liljohnny's Avatar
Quoted: 2 Post(s)
I think there's a way to reprogram the auto up feature. It goes something like roll the window all the way down and then all the way back up and hold it in the up position for a few seconds after the window has completely closed. I think this resets it....anyone else care to chime in?
Canucks Rool!
2002 3.5 Ruby
Blacked Out Chrome
Feedback Thread
http://www.nissanclub.com/forums/ven...ck-thread.html
liljohnny is offline
post #4 of 5 Old 11-05-2010, 03:05 AM Thread Starter
Thanks guys, I am gonna try it in the morning. I thought I broke something
post #5 of 5 Old 11-05-2010, 03:15 AM
Common sense advocate
monster289's Avatar
Quoted: 31 Post(s)
This is a little quirk with our cars. It will probably happen to you again. It's a very simple fix, and it even works while you're driving.
monster289 is offline
Closed Thread
