Engine turns over but won't start - Nissan Forums : Nissan Forum
post #1 of 16 Old 02-06-2011, 04:58 PM Thread Starter
Hello everyone, hoping you can help me. I did a search prior to posting but didn't see anything exactly like what I am experiencing. I have a 2007 Altima S with 43k miles.
The car experienced no problems starting prior to today. Yesterday I started it, drove it, came home and parked without any hint of a problem. Today I went to start the car and the engine turns over very sluggishly but will not start. So far, I've checked the following:
Battery is OK
Fuel pump energizes on accessory mode
Fuel pump relay fuse is fine
Any suggestions on what to try next would be appreciated. I have the extended warranty with roadside assistance but if it's something simple I can check/replace myself I'd rather do that first before returning it to the dealership. Thanks for any help you can provide.
timko27 is offline
post #2 of 16 Old 02-06-2011, 05:25 PM
┌∩┐(◣_◢)┌∩┐
l32nissan's Avatar
bad gas... bet ya gor a slug of h2o in yer lines...
where did ya buy yer gas?
l32nissan is offline
post #3 of 16 Old 02-06-2011, 05:29 PM Thread Starter
Not sure if that is the problem. I haven't gotten gas recently, I'm still at about 1/4 tank from the previous fill-up. At that time however when I did fill it up I got the gas at the BP station I have used almost exclusively since I purchased the car.
timko27 is offline
post #4 of 16 Old 02-06-2011, 05:36 PM
xeene's Avatar
Quoted: 6 Post(s)
what's temperature been like outside where you live? and how do you know battery is ok? why i'm asking, battery might have juice left it in but not enough amps to crank it in cold temperatures, which what usually happens when batteries die.
nissan factory shop manuals
xeene is offline
post #5 of 16 Old 02-06-2011, 05:36 PM
┌∩┐(◣_◢)┌∩┐
l32nissan's Avatar
hmmm... bp is usually good stuff... so i doubt that would be the problem then... the reason i asked was because i know a lot of people tend to go where gas is cheaper... and usually the cheapest gas around is a the murphy usa stations at walmart. that shit sucks... i know tons of people that have gotten bad gas at different murphy stations.
i use shell v-power... it's been great to me so far.
you may end up have'n 2 take it 2 nissan... they should give you a loaner car...
post #6 of 16 Old 02-06-2011, 05:38 PM
┌∩┐(◣_◢)┌∩┐
l32nissan's Avatar
Originally Posted by xeene View Post
what's temperature been like outside where you live? and how do you know battery is ok? why i'm asking, battery might have juice left it in but not enough amps to crank it, which what usually happens when batteries die.
this is true... is it the same battery that came with the car? it could be time for a new one...
post #7 of 16 Old 02-06-2011, 06:10 PM Thread Starter
It's been about in the mid-thirties here where I live for the past week or so. I presumed that the battery is OK based on the fact that:
a) I haven't noticed any lack of cranking power even a few weeks ago when it was in the single digits.
b) it is turning over (in my opinion) strong enough to start.
I realize these aren't quantitative or measurable opinions but that's all I have to go by right now. I don't have another vehicle available to me right now to jump start it to completely rule out the battery.
timko27 is offline
post #8 of 16 Old 02-07-2011, 04:01 AM
Altima FTW
BigTw1st's Avatar
Quoted: 1 Post(s)
I'd have to say battery as well, these batteries are known to go out prior to the 3yr mark. Take it up to auto zone and have them test it out for free.
2007 2.5S Radiant Silver
Depo Black & Clear Headlights_Depo Chrome LED Tails_V-LED Parking Lights_Stealth Bulb Turns_DDM 6000k HID_V-LED 6000k Interior/License Plate_OEM Color-Matched Grille_17" Konig Incident Wheels_Fujita SRI_OEM Spoiler_De-badged_Tinted Windows_Kenwood KDC-MP442U_Polk MM651_Infinity Reference 9612i_JL 10W1v2-4_Eclipse EA4100 & 3122 Amps_Monster Wiring
BigTw1st is offline
post #9 of 16 Old 02-07-2011, 02:00 PM
hazmat's Avatar
The first thing to check is to make sure that there is no corrosion on the battery terminals.
2008 2.5SL
Sonoma Sunset
2007 FX35
Autumn Copper
hazmat is offline
post #10 of 16 Old 02-07-2011, 10:07 PM
R30
Right!
Clean those battery posts and leads. Check battery level and fill with distilled water if low. Recharge battery and make sure that the engine accessory mode has not been mistakenly left on (Don't ask me why-lol).
Just went through this last month. This solved the problem.
R30 is offline
post #11 of 16 Old 02-08-2011, 05:51 PM
jdublup's Avatar
Quoted: 11 Post(s)
2 days later...so what was it, or is your car still dead?
2010 G37x 7AT--Black Obsidian on G37 Coupe Sport 19s
Previous:
07 Altima 3.5SE CVT--Black w/ Charcoal Leather--35% Tint, Custom Fiberglass Enclosure
92 Sentra 2dr--Black w/ Gray Int--238k miles
DMV Area Roll Call
Come rep DC, MD, and VA!!!
jdublup is offline
post #12 of 16 Old 02-09-2011, 12:51 AM Thread Starter
Battery was the issue. I was able to get up to the auto parts store yesterday once my other car was back. It's funny because you drive old cars all your life you always think mechanical when a problem occurs, sometimes overlooking the obvious.
Thanks everyone for your assistance!
timko27 is offline
post #13 of 16 Old 04-04-2011, 05:34 PM
A d m i n
Quoted: 6 Post(s)
just wanted to add i had same prob this am (turning over but just would not fire up) and put it on the charger for an hour and she started..... albiet not too easily.
my terminals are both corroded too - one not too bad but the other is under a plastic cap so i never see it but when i put the charger on it i noticed it was corroded.
thanks to those who helped timko bc you helped me too
2013 Nissan Rogue SV
2014 Honda Odyssey EXL Smokey Topez
2002 Honda Odyssey EXL GG (Up for sale)
Habs11 is offline
post #14 of 16 Old 04-04-2011, 05:37 PM
Altima FTW
BigTw1st's Avatar
Quoted: 1 Post(s)
^Remove the corrosion as its likely the culprit here, a little baking soda + water or coca-cola (then rinse after with water) will take it right off.
BigTw1st is offline
post #15 of 16 Old 04-04-2011, 06:31 PM
Quoted: 6 Post(s)
keep in mind, in newer car the battery doesn't necessarily have to be dead for it to not start. I found it out the hard way myself when mine died going down the road. apparently (according to Nissan) if the battery isn't putting out 12V the car will shut itself down to protect the computer and other electronics.
1998 nissan 200sx se (daily driver)
2007 nissan altima 2.5s cvt (wife/family car)
2012 chevy camaro (weekend toy)
jd10013 is offline
