Vibration During Slow Acceleration - Nissan Forums : Nissan Forum
post #1 of 34 Old 02-10-2011, 01:18 PM Thread Starter
sikk08's Avatar
Quoted: 2 Post(s)
07 Nissan Altima 2.5SL
When I'm accelerating slowly, from around 40km-65km, my car begins to vibrate. Even the passenger can feel it. It feels as if something in the front end (engine area) is vibrating. My acceleration pedal also begins to vibrate. It happens mostly during school zones, or low speed areas. If I accelerate quickly, then the vibration doesn't happen, which I mostly do so I can avoid it. It's fine on highways or high speed areas, it's just when I'm going slowly.
I took it to the dealership and the guy said that's normal. It's trying to shift gears but unable to do so because I'm accelerating slow (or something).
Is that true? Or is there a problem? Does anyone know the real reason as to why it's vibrating?
sikk08 is offline
post #2 of 34 Old 02-10-2011, 01:29 PM
jdublup's Avatar
Quoted: 11 Post(s)
Tires balanced???
2010 G37x 7AT--Black Obsidian on G37 Coupe Sport 19s
Previous:
07 Altima 3.5SE CVT--Black w/ Charcoal Leather--35% Tint, Custom Fiberglass Enclosure
92 Sentra 2dr--Black w/ Gray Int--238k miles
DMV Area Roll Call
Come rep DC, MD, and VA!!!
jdublup is offline
post #3 of 34 Old 02-10-2011, 01:36 PM Thread Starter
sikk08's Avatar
Quoted: 2 Post(s)
I'm a complete noob when it comes to cars. I'm not even sure what that means. Can I just take it to a mechanic and get the tires balanced?
sikk08 is offline
post #4 of 34 Old 02-10-2011, 02:14 PM
jdublup's Avatar
Quoted: 11 Post(s)
So when you start driving it's normal but between the speeds of say 25-45mph it kind of shakes and you can feel it in the steering wheel? Take it to a tire shop and see what they say. They would be the ones that would balance the tires, actually Nissan can balance your tires as well.
But looking at your first comment, it kind of sounds like the Nissan service guy is right. Have you had the car since 07 and this is the first time you have experienced it in almost 4 years, or did you get the car used and this you first experience with the CVT?
I've never experienced this in my 3.5 Altima, but I have in my wife's 07 Maxima (both have CVT). It's kind of like the car changes to a higher gear/ratio (CVT doesn't have gears) and is hesitating to accelerate. Kind of like if you drove a 5 or 6 speed manual transmission and started off in 1st gear (everythings good) but then you skip 2nd and go straight to 3rd gear and he would kind of shake until you go to a high enough speed for the gear. Other people have talked about it on the forum and said they adjust their acceleration.
Previous:
DMV Area Roll Call
jdublup is offline
post #5 of 34 Old 02-10-2011, 02:19 PM
Quoted: 1 Post(s)
I have a 2007 2.5 SL also and it behaves exactly as you describe. I believe this is considered "normal" behaviour but it's bothersome. You can get around this a bit by backing off and/or blipping the throttle when you feel the car vibrating.
07 Nissan Altima 2.5SL Niagara Gray
00 Honda Prelude Black (really miss this car, smashed from behind by dumb a$$ van driver)
90 Honda Prelude SR 4WS Black
Starvenger is offline
post #6 of 34 Old 02-10-2011, 02:25 PM Thread Starter
sikk08's Avatar
Quoted: 2 Post(s)
@jdublup
I bought the car used December 2010, not too long ago.
The steering wheel doesn't shake at all, it's mostly the pedal. You can also hear the vibration sound when it's happening.
I did come across this thread before posting
http://www.nissanclub.com/forums/200...der-40mph.html
But there are many different reasons in there about what could be causing the vibration. One guy did post that his dealer did say the same thing that mine did.
@Starvenger
I guess since it's normal, there's not much I can do. It does become really annoying though because sometimes I feel like driving slow. Also, when you're driving in traffic, it vibrates quite a bit. I would love to get rid of it.
sikk08 is offline
post #7 of 34 Old 02-10-2011, 02:30 PM
'07 Altima 3.5SE
Ralan07's Avatar
Quoted: 14 Post(s)
Never experinced this, however, mine's the 3.5. 40k miles.
Ralan07 is offline
post #8 of 34 Old 02-10-2011, 03:08 PM Thread Starter
sikk08's Avatar
Quoted: 2 Post(s)
Mine has approximately 87k km on it. Bought it at 82k.
sikk08 is offline
post #9 of 34 Old 02-10-2011, 03:18 PM
Motivated
StormzUSMC's Avatar
thats much more common in a manual car not automatic...my maxima is smooth as butter....
check tire pressure, get them rotated, and have your alignment checked...take it to a shop that specializes in suspension and wheels, only reason i take my car to a dealer is if they are doing warranty work
http://www.cardomain.com/ride/3151091
02 Maxima
I'd rather be whacking Tango's
StormzUSMC is offline
post #10 of 34 Old 02-10-2011, 04:10 PM
Altima FTW
BigTw1st's Avatar
Quoted: 1 Post(s)
Go to discount tire/NTB a place like that and have them check out your tires. If that doesn't work the balance shaft may be out of timing a little bit at low speeds which could be causing the vibration.
2007 2.5S Radiant Silver
Depo Black & Clear Headlights_Depo Chrome LED Tails_V-LED Parking Lights_Stealth Bulb Turns_DDM 6000k HID_V-LED 6000k Interior/License Plate_OEM Color-Matched Grille_17" Konig Incident Wheels_Fujita SRI_OEM Spoiler_De-badged_Tinted Windows_Kenwood KDC-MP442U_Polk MM651_Infinity Reference 9612i_JL 10W1v2-4_Eclipse EA4100 & 3122 Amps_Monster Wiring
BigTw1st is offline
post #11 of 34 Old 02-11-2011, 01:14 AM Thread Starter
sikk08's Avatar
Quoted: 2 Post(s)
Okay, cool. Thanks for the help. I'll make a list of all the suggestions and hopefully get it checked out tomorrow.
sikk08 is offline
post #12 of 34 Old 02-11-2011, 04:32 AM
3.5 is not cvt if im not mistake therefore you wouldnt feel the vibration in a 3.5. I have a 08 2.5 and i know what you are talking about and i am pretty sure its just the way the cvt works. its a different type of transmission.
xorox is offline
post #13 of 34 Old 02-11-2011, 04:33 AM
Altima FTW
BigTw1st's Avatar
Quoted: 1 Post(s)
^They do offer the 3.5 in CVT or 6-speed manual.
BigTw1st is offline
post #14 of 34 Old 02-11-2011, 04:53 AM
'07 Altima 3.5SE
Ralan07's Avatar
Quoted: 14 Post(s)
^^ Mine is 3.5 with the CVT.
Maybe this is only on the 2.5's? Ive heard of problems arising that only affects the CVT's in either the 2.5 or 3.5. This may not really mean anything, but if you have it, does this problem appear if you are in manual mode?
Ralan07 is offline
post #15 of 34 Old 02-11-2011, 04:54 AM
Motivated
StormzUSMC's Avatar
drive another cvt with same engine see if it happens i guess
02 Maxima
