Spark Plug socket - Nissan Forums : Nissan Forum
post #1 of 19 Old 07-25-2011, 12:43 AM Thread Starter
Quoted: 5 Post(s)
Spark Plug socket
I want to buy the correct socket to remove my 2009 2.5's plugs.
What I need is a 16mm thin wall socket which a couple of online places do have but the 5/8" (15.875mm) are far more popular and have more options eg. magnet, retaining ring etc.
If I cant easily find a 16mm locally will the 5/8" socket work?
streak2 is offline
post #2 of 19 Old 07-25-2011, 05:15 AM
Ultra Premium Member
Tom Brady's Avatar
In all of my efforts with various 5/8" sockets, they just spun around the spark plug.
2007 Altima 2.5 S - Precision Gray
Mods: Altima SE-R gunmetal wheels K&N Typhoon intake Stillen cat-back exhaust Bullydog GT Tuner Racingline front strut tower brace Racingline battery tie down painted red taillights Autokits rear diffuser precision gray painted eyelids GTR starter button oem leather steering wheel oem leather shift knob foglights oem style spoiler oem "altima" door sills Duralast Gold battery Denso iridium plugs oem all weather floor mats Nismo oil cap Sylvania zXe headlight bulbs
Tom Brady is offline
post #3 of 19 Old 07-25-2011, 05:38 AM Thread Starter
Quoted: 5 Post(s)
Thanks Tom. I will hold out for a 16mm then. I see that some Sears do carry them otherwise I'll order online.
streak2 is offline
post #4 of 19 Old 07-25-2011, 03:33 PM
jdublup's Avatar
Quoted: 11 Post(s)
16mm/25.4mm per inch= 0.629 inches
5/8"= 0.625 inches
if you need a 16mm, 5/8 is smaller so it might not be big enough.
Just asking...but why are you changing out your spark plugs on a 2 year old car? Do you have 105k miles on the car?
2010 G37x 7AT--Black Obsidian on G37 Coupe Sport 19s
Previous:
07 Altima 3.5SE CVT--Black w/ Charcoal Leather--35% Tint, Custom Fiberglass Enclosure
92 Sentra 2dr--Black w/ Gray Int--238k miles
DMV Area Roll Call
Come rep DC, MD, and VA!!!
jdublup is offline
post #5 of 19 Old 07-25-2011, 03:42 PM Thread Starter
Quoted: 5 Post(s)
I bought the car used and just wanted to do a visual inspection of the plugs and to see what type and brand have been used.
streak2 is offline
post #6 of 19 Old 07-25-2011, 03:52 PM
jdublup's Avatar
Quoted: 11 Post(s)
I think it would be safe to say the OEM plugs are still in there.
Good luck with finding a socket. Is there a difference in wall thickness for single or double hex sockets?
Previous:
DMV Area Roll Call
jdublup is offline
post #7 of 19 Old 07-25-2011, 03:58 PM Thread Starter
Quoted: 5 Post(s)
All the texts recommend a deep thin wall six side socket.
streak2 is offline
post #8 of 19 Old 07-25-2011, 04:01 PM
hazmat's Avatar
Used standard deep wall 16mm 6pt socket on mine. Then used a piece of hose to remove the spark plug from the well. You don't really need a special "spark plug" socket.
2008 2.5SL
Sonoma Sunset
2007 FX35
Autumn Copper
hazmat is offline
post #9 of 19 Old 07-25-2011, 08:33 PM
Tom Brady's Avatar
2007-2009 Nissan Altima Spark Plugs Replacement Procedure = use a 14mm socket
Last edited by Tom Brady; 08-02-2011 at 04:16 AM. Reason: the link I had up before gave wrong information
post #10 of 19 Old 07-25-2011, 08:57 PM Thread Starter
Quoted: 5 Post(s)
Thanks Tom, it really is that easy!
streak2 is offline
post #11 of 19 Old 07-25-2011, 10:41 PM
Tom Brady's Avatar
I just went and bought one for like, $8.00
The dealership wanted $80 to install them - even though the engine cover was already off, while they did the valve cover gasket job. I said, no... that'll be fine. For $80, I'll buy my own socket.
post #12 of 19 Old 07-26-2011, 04:26 AM
Common sense advocate
monster289's Avatar
Quoted: 31 Post(s)
Dedicated spark plug sockets have rubber inside the socket that holds the plug in the socket, and the rubber also protects the ceramic part of the plug from damage. They're nice to have around in your tool box, and it's a trivial expense IMO.
monster289 is offline
post #13 of 19 Old 07-26-2011, 01:45 PM
hazmat's Avatar
I am aware of this...and I have just about every size except the 16mm. I was just saying that it is not a necessary tool for this job.
2008 2.5SL
Sonoma Sunset
2007 FX35
Autumn Copper
hazmat is offline
post #14 of 19 Old 07-29-2011, 02:58 AM
Tom Brady's Avatar
Oh. 16mm was still too big. I had to buy another socket. 14mm.
...for the densos, that is.
So, just an fyi - its 14mm. Period. If you have densos.
post #15 of 19 Old 07-31-2011, 09:16 PM
Valley Forge
Cool Socket
Convenience is the key here. I have 07-2.5s and I needed 14mm socket. I ordered one and got the job done a lot easier. You probably will need to add a little grease like SilGlyde or something of that sort inside the rubber groove of the socket. I have seen in many cases that spark plug get stuck in the socket too tight; after installing a plug when I try to pull the socket the socket extender comes off and socket stays inside. If the socket is greased it comes off the spark plug easy.
Changed mine @92k miles. Idling is definitely smoother; did not test on highway yet. Not that much of a difference, but I would have needed to change the plugs soon any how. Top valve cover gasket is leaking a bit.
KnoX is offline
