Oil leak - Nissan Forums : Nissan Forum
post #1 of 14 Old 08-28-2011, 06:30 AM Thread Starter
Oil leak
Hi Guys,
I have an oil leak that I can't seem to figure out. It is without a doubt coming from the passenger side of the car. If you are facing the car the leak is coming from somewhere around the 2 o'clock position and is about 6 to 10 inches in. I've looked everywhere but I have no way of getting completely under the car. It appears to be coming from the one place that I can't get my hand on from the top or see from the bottom. I am hoping that their is something going on with a seal or sensor or something...Any ideas ?
domga82 is offline
post #2 of 14 Old 08-28-2011, 07:47 AM
frotes_88's Avatar
2.5 or 3.5? If you have a 2.5 my first instinct would be to the check oil filter since the leak is on the passenger side. It's behind a plastic cover behind the wheel; if it's loose give it a good hand-tighten.
frotes_88 is offline
post #3 of 14 Old 08-28-2011, 05:43 PM Thread Starter
It's a 2.5..I checked the oil filter already and the oil has been changed at the dealership since the oil started..they were just too "busy" to find the leak for me. I'm pretty sure that it is something along the back side of the engine..
domga82 is offline
post #4 of 14 Old 08-28-2011, 11:37 PM
Quoted: 6 Post(s)
just take it to the dealership or a shop. they'll just put a dye in it (like with freon leak) and then have you bring it back in a couple days. you never said what year it is, or how many miles you have, but if it's an 07 or 08 with a lot of miles most any of the gaskets could be in need of replacement. most cars I've owned have developed very minor leaks at various gaskets (most often valve cover) once the hit 100k or more.
1998 nissan 200sx se (daily driver)
2007 nissan altima 2.5s cvt (wife/family car)
2012 chevy camaro (weekend toy)
jd10013 is offline
post #5 of 14 Old 08-29-2011, 05:00 PM Thread Starter
2007 with 74,000 miles. The valve cover gasket was replaced and their was already a minor going on prior to it being changed. Could I go and buy that dye on my own ? I've looked around at Advance auto parts and couldn't find it.
domga82 is offline
post #6 of 14 Old 08-29-2011, 05:03 PM
Quoted: 6 Post(s)
don't know. but you'd need an ultraviolet light to see it anyway. it's not expensive to have done, a lot of places won't even charge you.
jd10013 is offline
post #7 of 14 Old 08-29-2011, 05:32 PM
jdublup's Avatar
Quoted: 11 Post(s)
Kind of surprising that Nissan didn't look for it, considering it would be potential business. I am a repeat customer at the dealership here in Chantilly, VA and when we took our Maxima in for a leak, they found the power steering fluid leak, as well as a bad seal on the CVT that was causing a slight leak (replaced under 120k warranty). They were looking for all the money they could. The mechanic took me out to the shop and show me where everything was leaking before they started the work. Also had a bad motor mount during that visit.
Try PM Adamechanic (I think that's his name) on here and see if he can help. He is a Nissan tech.
Where are you located? That information would be great in you profile info as well as vehicle info (Year/trim model/engine) in your signature, so members can have a little more info to help out.
2010 G37x 7AT--Black Obsidian on G37 Coupe Sport 19s
Previous:
07 Altima 3.5SE CVT--Black w/ Charcoal Leather--35% Tint, Custom Fiberglass Enclosure
92 Sentra 2dr--Black w/ Gray Int--238k miles
DMV Area Roll Call
Come rep DC, MD, and VA!!!
jdublup is offline
post #8 of 14 Old 08-29-2011, 06:58 PM
Quoted: 6 Post(s)
yea, I was surprised by that too. every time I've had a car at the shop, weather it be for work or an inspection, and I've had an oil leak they've always just put the dye in and told me to come back and they'd find and fix the leak.
jd10013 is offline
post #9 of 14 Old 08-29-2011, 11:05 PM
Hey man, where's my car?
velanzia's Avatar
hey did you mention that if i face the car the leak is at 2'0 clock? that is driver side, no? that's where the tranny is (2.5, not sure about 3.5 - maybe the same spot). could it be cvt? i would take to to dealt anyways.
velanzia is offline
post #10 of 14 Old 08-30-2011, 05:48 AM Thread Starter
Every time I step foot in the dealership I hear someone talking about how they don't have enough mechanics. So if you don't make an appointment or show up before 8 a.m. you can forget about getting anything done other than an oil change. Even the oil change will be an hour and a half wait.
I was saying 2 o'clock position from the passenger side tire if you are facing the car. / <-- That direction from the passenger side tire. It is without a doubt an oil leak coming from the back side of the engine.
domga82 is offline
post #11 of 14 Old 08-30-2011, 12:44 PM
velanzia's Avatar
^-- Sorry, probably I misread. Anyway it could be the oil filter or the gasket as some other members pointed out. Or it may even be the oil pan washer. You can check the oil filter by lying on the floor, in front of passenger side wheel - pull the plastic cover between wheel well and engine bay (just above the drive shaft), you should see the filter top, maybe run your finger near the bottom side.
You are true about dealership. i think they want you to schedule an appointment because they want to diagnose the issue and, of course charge. i have brake booster issue and when i told them that i have such a problem, diagnose charge was $50 via an appointment.
If your dealership is busy, you can always try a different one tho. Hope you issue get resolved soon!
velanzia is offline
post #12 of 14 Old 08-31-2011, 02:13 AM
I never got a pm. Thanks for the kick back jduplup. The oil pans on Nissans very rarely leak unless you hit something with them. Anyone who has said they had a leaking oil pan was likely fed a line and the real issue was fixed without being informed of it (to save face). The number one culprit for oil leaks is in fact the oil cooler. There are two kinds that leak. You have the round ones as found on most 3.5's, 4.0's, and 5.6's that the oil filters screw directly on. The seal normally gets brittle and needs to be changed by removing the filter, then removing the banjo bolt with a 24mm. Pull the cooler towards you and replace the seal on the backside making sure the o-ring is inside the inner lip. The other kind is a square pancake cooler that sits midway up the back of most newer 4 cyl's. Simply remove the bolts, replace the metal gasket and reinstall. Best of luck.
ADAMECHANIC is offline
post #13 of 14 Old 10-10-2012, 04:00 AM Thread Starter
I didn't realize that I first started this post over a year ago. The small leak that seemed to have disappeared turned in to a flow of oil pretty much overnight. I found the leak, it is coming from the oil cooler, but the metal gasket is in tact. The oil leak is coming from the top of the oil cooler, it is mid way between two bolts on the square part of the oil cooler. The dealership told me that their isn't an O-ring in the 4 cylinder version, only in the 6, so it looks like I am going to be out $300-$400 !! What a great day..
2007 Nissan Altima 2.5 Base Model--No Extras Yet
Columbus, Georgia
domga82 is offline
post #14 of 14 Old 10-10-2012, 06:24 AM Thread Starter
I found a TSB on it. NTB-11-015a
Columbus, Georgia
domga82 is offline
