Clicking noise PLEASE HELP - Nissan Forums : Nissan Forum
post #1 of 13 Old 09-28-2011, 07:38 AM Thread Starter
Ok so my issue is when I let go of the brakes and start to accelerate, there is a clicking noise from the drivers side. It only does it once i let go of the brakes and accelerate. Anyone know what it could be?
Belarus240sx is offline
post #2 of 13 Old 09-28-2011, 04:51 PM
does it do it all the time ?
2007 Nissan Altima 3.5 Se
- Dark Slate
- Sports Package
- 6 Speed
- DDM Tuning 3K Fogs
Best 1/4 : 14.504@ 97.67mph
fishstick is offline
post #3 of 13 Old 09-28-2011, 09:46 PM Thread Starter
Only on stop and go
post #4 of 13 Old 09-29-2011, 03:42 PM
Every time the car is started the first time it hits about 10 mph there will be a thud or clunk from somewhere in the engine bay. This occurs only once per trip and is a normal part of the ABS system checking itself. There's a thread on it. If that's what you're experiencing, don't worry about it I feel it through the pedal as well...
2011 Altima 3.5 SR
PM me if you've also noticed misbehavior in the trip MPG rating and aren't afraid to admit it! http://www.nissanclub.com/forums/200...ng-altima.html
Last count: 3, including me, have noticed this misbehavior.
ThirdVQ is offline
post #5 of 13 Old 09-30-2011, 12:46 AM Thread Starter
It clicks every time I drive and does it constant when I stop and go. It is loud. I was driving 2 cars behind mine and could hear it.
post #6 of 13 Old 09-30-2011, 01:05 AM
07VQ356MT
Quoted: 4 Post(s)
Does the clicking sound get louder the faster you go? Does it get louder when you are taking a turn or is it constant going straight or taking a turn? Clicking sounds like a CV axle, which is pretty easy to replace. You can get a reman'd unit for about $80.00 from O'Reilly Auto Parts List: CV Half Shaft / Axle Shaft - 2007 Nissan Altima | O'Reilly Auto Parts
How many miles do you have on your car?
Power Acoustik PNX-761, Alpine Type R 6.5" Comps, JBL P963 6x9, Kicker CVX124 in 1.8 cu/ft vented box tuned at 36Hz, Hifonics BRX1200.1D, JBL GTO1004, 1/0 power/ground wire, XSPower D5100 battery, Redline MT-85, K&N Intake, RL Traction Rods, BC Racing Coilovers, RL RSB, RL Endlinks, RL Y-Pipe, 2.5" Lou's Custom Catback, Power Stop Crossed drilled/slotted rotors, SS lines, DOT 4 fluid, debadged
sbuswell is offline
post #7 of 13 Old 09-30-2011, 05:02 PM
I have a clicking sound on mine and I thought it was the CV axle but someone told me since I have aftermarket rims on my car its more likely the cotter pin. Havent had any time to take off the rim to check but it would click only when I accelerate. If im slowing down it doesnt click, but when I accelerate you can hear the click, click, click, and then it stops after the car picks up speed. But its not as loud as you described.
2007 Altima 2.5s
-22x9" Fusion Nitro Diamond Cut Black
-235/30/22 BS Tire
-7" Double Din JVC
-5% Tint All Around
-6000K Umnitza 55W H11 HID Kit
-DEPO LED Taillights
Mirza is offline
post #8 of 13 Old 09-30-2011, 10:53 PM
DayWa1k3r's Avatar
I would try greasing the ends of the cv axles where they meet with the spindle. That's what it sounds like it could be to me.
DayWa1k3r is offline
post #9 of 13 Old 10-01-2011, 03:16 AM
07VQ356MT
Quoted: 4 Post(s)
Cotter pin? What cotter pin the lower ball joint cotter pin? There is no cotter pin that should be hitting the inside of your rim, you'd see it anyways. Clicking sounds are almost always CV's. I'd just replace the axle. It's pretty easy and not very expensive. Also if gone unchecked and it snaps you could do a lot damage or get into an accident.
You could always bring it to a shop and have them check it out with a mechanics stethoscope. That'll ID the issue for you quickly.
sbuswell is offline
post #10 of 13 Old 10-09-2011, 12:51 AM
I just had a "ticking" or "clicking" noise resolved on my new '11 Coupe SR. The noise came from the driver's side front wheel. The tick would occur as the wheel made revolutions (i.e. longer intervals at slower speeds and shorter intervals at higher speeds). I could hear it clearly under 20 mph and when driving past enclosed areas. It sounded very similar to rock being stuck in the tread.
I took the advice of what some others said on this forum and told the dealership about the cotter pin which holds the center bolt on the hub assembly (behind the wheel). Sure enough, the tech found that the cotter pin was "loose" so he tightened it by bending the prongs and that resolved the issue.
I urge anyone who hears a "ticking" sound that matches the revolutions of the wheel to check out the cotter pin and see if it is loose. I heard a bad cv joint will make a "click" when turning, but not so much when just driving straight. There are at least 3 others who have had the same issue with their cotter pin "ticking".
zion_leader is offline
post #11 of 13 Old 10-16-2011, 12:14 AM
altimate won's Avatar
i have that same problem, when i stop at a light or stop sign, there is a small click sound when i pull off..it's pretty annoying. reading these posts im relieved, i thought it was the cvt..
4500k Xenons... 20% tint all round... CVT F'N rocks...
altimate won is offline
post #12 of 13 Old 10-16-2011, 02:41 AM
Ranger052.'s Avatar
That happened to my car one month ago, and I thought that it was the CV joint but not I was wrong actually the problem was a motor mount.
Take out the black cover that is over the engine and check the motor mounts.
Have someone on the car and do this, put it in reverse and without pressing the brake put it back in D and then R, Do it like that, so that way you can be outside the car with the hoop open hearing from where the noise is coming, your friend can help you or your wife.
That is exactly what I did in the dealer because in dealer they where saying that it was impossible to find from where the noise was coming so, I did that and thanks for that now my car is fixed and running with all brand new motor mounts
Don't look at my grammar, English is my second language.
Ranger052. is offline
post #13 of 13 Old 10-20-2011, 06:47 AM Thread Starter
Update. It was my left arm link. I had it replaced yesterday and the clicking went away.
