Originally Posted by Eltringham
should i actually remove the brake light and housing from inside the car and then drop those wires down into the trunk?
you got it.
so lets make sure you have everything working correctly. Both brake lights in the taillights should work now that you reconnected the wires you cut. If you contect the clip from the spoiler light, to the 3rd brakelight harness that you will need to get to from inside the car first, now all 3 should turn on
