Parking brake not engaging - Nissan Forums : Nissan Forum
Old 01-17-2013, 01:37 AM
the parking brake in my 07 altima doesn't seem to be engaging. the light will come on, but the car will continue to roll even on a slight slope.
does anyone know how the parking brake works on the 07 altima? does it engage the rear disc brakes or is there a separate braking system somewhere?
Old 01-17-2013, 01:48 AM
RIZAMAN's Avatar
Shaving My Shoulders
If they retained the 3rd gen rear brake disc type, and I think they did, the e-brake engages a drum-style brake that acts on the inside portion of the rear disc.
In any case after 130,000+ miles on mine they still grab just fine on the OE e-brake pads. I would guess the cable needs adjusting...I think that can be done up on the handle end of it...Correct me if I am wrong by all means.
Edit: if you look at the spring in the pic between the pads there is also a sprocket like wheel that can be turned to adjust. The rear discs have holes in them (covered by rubber plugs) so you can turn the rotor (wheel off) to line it up to be able to adjust. I am not sure though where it is recommended the adjustment be made (at the handle end or the rotor end).
Sent possibly from the shitter on my HTC EVO, bizneeaatch...
|2005 Alty 3.5SE (AT)|HEAVILY MODDED|
Originally Posted by blackalti View Post
i could never just be a honda guy...i love torque too much...
Old 01-17-2013, 01:58 AM
can someone confirm rizaman's post? i just want to be sure that the parking brake system is separate from the disc brakes.
in any case, this is pretty weird. parking brakes aren't supposed to wear out on a car with 70,000 kms.
Old 01-17-2013, 02:04 AM
RIZAMAN's Avatar
Found these as well for reference...I know it's a 3rd gen, but just in case it'll help.
Closer shot:
Rear rotor with hole and plug:
Good luck bro...I agree, after 70,000 clicks they should not wear out.
The Following User Says Thank You to RIZAMAN For This Useful Post:
Old 01-17-2013, 02:12 AM
yup, it hasn't even been a week since i picked the car up from the dealer. i think i'll bring the car in and see what they can do. i only have powertrain warranty on it though.
Old 01-17-2013, 07:54 AM
dubya's Avatar
iTrader: 5 reviews
The time and effort Riza put into his replies.. you get a thanks from me at least!
http://www.nissanclub.com/forums/200...r-e-brake.html
Have a look at the last past by vqpower. Riza is the man.
DMV Area Altima's
Old 01-17-2013, 12:49 PM
monster289's Avatar
Not on a power trip
Parking brake just needs to be adjusted. Simple fix.
Old 01-17-2013, 01:00 PM
RIZAMAN's Avatar
Nah, just haven't contributed much in a while I though I should pay some dues with a tech post
Thanks for that though man - I appreciate it...Although I did forget the 4th gen e-brake was on the floor pedal-style
Old 01-17-2013, 03:05 PM
B15 B15 is offline
4th gen has the same set up. Just tighten the cable.
2010 370z- Sport/Touring/Nav/6MT
Old 01-17-2013, 03:33 PM
i took it to the dealer and it turned out that i wasn't doing it properly. i've never used the pedal ebrake before and was only pressing it lightly it until the brake light came on.
i feel like a fool, lol. thanks for the responses though... should be helpful for future reference.
