Pass. rear window not working. Master switch?
The rear window seems to have stopped working. Will not go down or up when using the driver switch or the one on the rear door. I do notice that the driver's switch is "jammed." if I pull up or push down on both of the rear window switches i notice that the left one does not move the same amount.
Does the driver's master switch control how the window operates, like a dual light switch in your house? Other than using a volt meter, is there a way to tell what is going on with these switches. Just went out recently as I usually hit the wrong button at the drive thrus and roll the driver rear down accidentally
Thanks, I remember reading somewhere that the driver door panel is the brain of the operations in these cars.
2008 Altima 2.5SL w/CVT Dark Slate **Stock**
