takeda intake sputter when sitting for long periods - Nissan Forums : Nissan Forum
Old 02-04-2013, 03:56 PM
I'm new to this site still n was wondering if anyone else had this problem...my rpms sit at about 900-1000 at idle n when I rev... The intake sputters....after I drive for a while b start up again its fine....only happens when I leave it overnight or after work (long periods)....
Is this a serious problem or can it be fixed? The first time the filter was a but loose.... So I tightened it.. Then its still happening....I have an 08 2.5 sedan
Old 02-04-2013, 05:32 PM
twista's Avatar
Canadian eh?
Could be signs of your cvt engine dying
2007 Nissan Altima 2.5
Nissan of the Month Winner Oct 2012
Pics/Description: http://imgur.com/a/uabGt#0
Old 02-04-2013, 05:55 PM
dubya's Avatar
iTrader: 5 reviews
Do you mean that your engine is idling erratically? If it is, check for a vacuum leak.
DMV Area Altima's
Old 02-04-2013, 07:38 PM
It almost sounds like the filter is trying to suck but is struggling...
Old 02-04-2013, 08:17 PM
dubya's Avatar
iTrader: 5 reviews
Did you try resetting your ECU? Disconnect the battery for a minute?
Old 02-04-2013, 08:22 PM
Not since I installed a few days ago...
It just started a couple days ago.... Perhaps clamps on the throttle are loose? I'm just worried it will affect the engine in the long run
Old 02-04-2013, 08:32 PM
twista's Avatar
Canadian eh?
Oh you just installed it? then for sure it's something to do with the intake itself. Take it apart and check for leaks, then install again tightly
Old 02-04-2013, 08:40 PM
I think if it were a leak it would do it all the time.... Only happens when car is completely cold?
Old 02-04-2013, 09:02 PM
dubya's Avatar
iTrader: 5 reviews
You put everything back together? You put the MAF sensor back, right?
Old 02-04-2013, 09:39 PM
N1rve's Avatar
Check the MAF connection. Make sure it's tight.
Remove the negative cable and wait for a few minutes (1-2), and then plug it back in. Start the car and listens for leaks.
If all else fails, reinstall your stock intake and see if it happens as well.
Did you recently change your oil btw?
11 Nissan Altima 2.5S Special Edition
Mods:
50% Front Windshield Tint
45% Front Window Tint
5% Rear Window Tint
OEM Nissan Scuff Plates
Steering Wheel Audio Controls
Automatic Headlights
OEM Fog Lights
OEM Splash Guards
All Weather Floor Mats
OEM Spoiler with LED Tail Light
Interior Third Tail Light Deleted
Leather Steering Wheel
Special Edition Badge
Upgraded Torque Rods
Old 02-04-2013, 10:41 PM
Yes sir
Old 02-04-2013, 11:02 PM
A better question would be "was the MAF installed facing the correct direction?"
~Mark
2010 Altima 3.5SR Coupe Fully Loaded- Eibach Springs/Racingline Y-Pipe/Takeda Intake
Nissan Factory Service Manuals (FSM):
http://www.nicoclub.com/FSM/
Old 02-05-2013, 01:17 AM
N1rve's Avatar
Originally Posted by jfw2 View Post
Yes sir
If you recently got your oil changed and its doing that... there's tsb for that.
Old 02-05-2013, 01:22 AM
Jus check maf orientation n tightened clamps....well see what happens...I suspect part of it is because it rubs against a soft foam covering the battery mount... But I guess time will tell . when I plugged in a scan tool it said mixture is too rich... Maybe I installed it wrong? Or that foam rubbing against the filter is the problem...
Old 02-05-2013, 04:52 AM
N1rve's Avatar
If it's too rich that means there is more gas than air. Are you sure there is nothing obstructing the filter or pipe?
