Dash removal - Nissan Forums : Nissan Forum
post #1 of 11 Old 03-22-2013, 07:11 AM Thread Starter
Dash removal
How difficult is it to remove dash completely? And will I be able to access the firewall in the upper right hand corner when facing the steering wheel?
Anyone ever done this or have pics?
brianhj is offline
post #2 of 11 Old 03-22-2013, 11:17 AM
What are you trying to do? Removing dash panels are always a pain in the a$$, specially these newer vehicles.
~Mark
SOLD: 2010 Altima 3.5SR Coupe Fully Loaded- Eibach Springs/Racingline Y-Pipe/Takeda Intake
Nissan Factory Service Manuals (FSM):
http://www.nicoclub.com/FSM/
VQP0WER is offline
post #3 of 11 Old 03-22-2013, 02:04 PM
rogoman's Avatar
Quoted: 22 Post(s)
Just like VQPOWER said, it is a real PITA. There are a lot of pieces that have to be removed in the proper order. Since there's a lot of plastic, it's very easy to break some of the snap-on connectors. Because of the many steps for removal, you need to download an FSM for your car; it has a detailed description for dash removal. Download an FSM from here:
Index of /FSM
KA-T for life, yo!
rogoman is offline
post #4 of 11 Old 03-22-2013, 06:32 PM Thread Starter
http://www.nissanclub.com/forums/200...-big-pics.html
Can I access the driver side firewall from the wheel well??? That would make this much easier.
Going to be running 0ga ground to battery
brianhj is offline
post #5 of 11 Old 03-22-2013, 11:09 PM
kscott's Avatar
Quoted: 7 Post(s)
A note of caution when taking things apart - some of the wire clips (e.g. the zip-tie clips on a standoff that snap into an oval hole, such as on the cable going into the steering column) are not sold as replacement parts unless you buy a new wiring harness. So don't cut them off with a wire cutter. Carefully take them apart so that they can be reused again.
kscott is offline
post #6 of 11 Old 03-22-2013, 11:29 PM Thread Starter
Good to know!!!
brianhj is offline
post #7 of 11 Old 03-25-2013, 02:49 PM
Vital's Avatar
Quoted: 7 Post(s)
iTrader: 11 reviews
While it is defiantly not the easies project but it's not as difficult as it seems from the posts above. If you are a bit handy and feel comfortable with basic tools you shouln't have issues with taking the dash off.
Me and a friend (who knows nothing about cars, he was there for "extra pair of hands" which you'll need for this project) took it off and installed it back it in just a few hours.
Here's some pics of firewall area, hope it helps.
Vital is offline
post #8 of 11 Old 03-25-2013, 03:07 PM Thread Starter
Wow thanks for pics!!!
I don't think it will give me the access I need.. Hopefully the wheel well will
brianhj is offline
post #9 of 11 Old 03-25-2013, 03:08 PM
BoSs DoN bIG WaVeY
eskalaid's Avatar
Quoted: 1 Post(s)
should i buy a new dash since im doing the leather swap??
eskalaid is offline
post #10 of 11 Old 03-25-2013, 03:14 PM
Vital's Avatar
Quoted: 7 Post(s)
iTrader: 11 reviews
Wait, you're just trying to move 0g wire?? You really don't need to take dash of for THAT! There's a LOT of poeple who have aftermarket sound systems and none of them removed the dash. Am I missing someting here??
If you get it for close to free - sure.
I don't think it makes sense to actually buy it with all the work involved and the fact that you will still have white pieces inside your car. Dash alone doesn’t completely convert your interior into fully black.
EDIT: there's no dashes on ebay right now but last I checked they were crazy expensive. Mostly due to airbags deploying in most accidents so when you actually find one out of salved car that didn't have those bags deployed it'll cost you.
Vital is offline
post #11 of 11 Old 03-25-2013, 08:30 PM
rogoman's Avatar
Quoted: 22 Post(s)
The late model Altima has a major wiring harness going through the firewall on the driver's side just behind the wheel-well inner fender protector. Just loosen the protector and pull it forward and you should see where the electrical harness is. This should work out real nice for you as the battery is also on the same side.
KA-T for life, yo!
rogoman is offline
