Gen4 VQ Belt Squeak Weirdness - Nissan Forums : Nissan Forum
 1Likes
  • 1 Post By d0ugmac1
post #1 of 6 Old 06-05-2017, 01:46 PM Thread Starter
d0ugmac1's Avatar
Quoted: 692 Post(s)
So, I have been plagued by the sporadic cold weather squeal through the winter which would go away once warmed up. Then come spring all was good, except above 2500rpm I'd get this weird rpm related chirping which got quite loud. Chirping happened regardless of parked or driving and with or without AC on. I prelim'd it as one or more of the idler pulleys/auto tensioner.
Removed the wheel on the weekend to see if I could narrow it down...no dice. I removed then removed the belt and the fun began.
1. auto tensioner pulley spins quite freely, but as it slows down it has a kind of metallic ringing/ting ting noise. There is some lateral play in the bearing
2. upper idler also spins quite freely, but makes a rubbing sound as it slows down, more play on this pulley
3. lower idler spins smoothly and silently, but not freely. It comes to stop in a revolution or two, unlike the 5-10 the others manage. No play, no noise just a sense of a little drag.
I checked the other pulleys, and notice that
4. small amount of play in the a/c compressor clutch pulley (no noise but definitely a little lateral movement when clutch not engaged)
I also noticed that when cold, the chirping happened even at idle. On a whim and a hunch, I used the back of a screwdriver to gently depress the edge of the ac clutch against the spinning pulley (engine running) but not enough to cause rotation, a little puff of rust dust and the chirping was gone!
I will continue to test, but I think I have resolved the annoying squeak symptom, but have now discovered other wear areas of concern.
Anyone with thoughts or input into what is acceptable bearing play on the idlers and AC pulley should feel free to jump in!
Nissan OEM HIDs with Morimoto bulbs/harness, RacingLine FStB & RSwB @ 200%, ETI LED Fogs,
Altima FSMs & Useful posts: Bose Upgrade / Alternator / Bad Ground / Rear Brakes / TPMS Reset /
/ Spurious ABS / Audio Power / ABS Diag / Steering Lock / Lower VQ rad hose / VQ Belt Squeak
d0ugmac1 is online now
post #2 of 6 Old 06-18-2017, 05:31 PM Thread Starter
d0ugmac1's Avatar
Quoted: 692 Post(s)
Fun conclusion post. Short story:
Turned out to be the one that I actually thought was ok and the auto tensioner is frickin' near impossible to remove without removing the PS pump/pulley....read on
As above the auto tensioner and upper idler had play and probably needed replacing, but the lower idler which had no play had clear evidence that it was rubbing on the long mounting bolt. Seems the lower idler actually has two? bearings inside and from what I could see the inner bearing seal had gone a long time ago. The inner race was rubbing on the bolt, you could see the shiny patch where it made contact on removal.
Fun fact #1 the Gates part is almost twice the Dayco price for this pulley, I went Dayco for this part and saved $30 (~50%)
Fun fact #2 the Gates parts come with new bolts and dust shields, which are useless, I couldn't even get a stubby 17mm socket on the replacement bolt, even using a simple 3/8" breaker...just wouldn't fit. I cleaned up the original shields (much better quality) and re-used the original 13mm bolt. Next time I'll just buy all Dayco and not pay 'extra' for the useless hardware included with the Gates parts.
Fun fact #3 the top auto tensioner assembly mounting bolt is directly behind the outer rim of the PS pulley. No way you can get any kind of socket on this. I wound up using extra long box end 13mm wrench with a slight angle of 15'?? I was just able to get this on enough of the bolt head to break it loose, then had to put it on another 50x to get the bolt far enough out to remove with fingers
Fun fact #4 You cannot remove both the upper and lower auto tensioner bolts with tensioner in the same position. The lower only comes out when the tensioner is free, and the upper only comes out when the tensioner is locked in place with your 6mm allen key through both holes. So this means you have to lock it to remove the belt, unlock to loosen but not remove the lower bolt, relock it and work on the upper bolt, then careful unlock it again to remove the lower bolt and assembly. Installation is the reverse of this nightmare.
Fun fact #5 For whatever reason I removed mine still in the locked position...so to get your allen key back out...I used some vice grips to 'pinch' the two parts enough to remove the key, but when you unlock the vicegrips...it expands more than they do, so you have to tap the tensioner off the vicegrips...sigh.
All good now though...$180CDN later (I put a new belt on too).
post #3 of 6 Old 06-19-2017, 01:24 AM Thread Starter
d0ugmac1's Avatar
Quoted: 692 Post(s)
Fun fact #6 you cannot torque the upper auto tensioner bolt, or the upper idler bolt due to clearance issues. I used the R. U. Gudenteit method. The auto-tensioner torque is supposed to be 25 ftlbs, and the idler bolts 29.5 ftlbs ish. Page EM-121 if you care to double check.
Fun fact #7 the Gates parts were Made in Canada, eh?!
08AltimaDriver likes this.
post #4 of 6 Old 06-19-2017, 01:09 PM
MRR
2010 2.5 SL
Quoted: 134 Post(s)
Turning a wrench eight degrees at a time sucks. Things like that always make me wonder how cars manage to get assembled in the first place.
FFun fact #4 You cannot remove both the upper and lower auto tensioner bolts with tensioner in the same position. The lower only comes out when the tensioner is free, and the upper only comes out when the tensioner is locked in place with your 6mm allen key through both holes. So this means you have to lock it to remove the belt, unlock to loosen but not remove the lower bolt, relock it and work on the upper bolt, then careful unlock it again to remove the lower bolt and assembly. Installation is the reverse of this nightmare.
Congratulations on figuring it out, though. I would have gone 90%, become stuck, and put it all back together without fixing anything.
When this came up on my motorcycle, we just took a 12" wrench and a spring scale. Pull on the scale to tighten until the correct torque. Bit more difficult when the only wrench that fits is 6" and your scale doesn't go up high enough.
Glad you got it all working again.
MRR is offline
post #5 of 6 Old 06-19-2017, 05:54 PM Thread Starter
d0ugmac1's Avatar
Quoted: 692 Post(s)
^^ Thanks for the spring scale idea! I now have a *real* reason to get one...
Now I can finally answer M. I. Teitenhoff?
post #6 of 6 Old 06-19-2017, 05:57 PM
MRR
2010 2.5 SL
Quoted: 134 Post(s)
Glad to be of assistance. If I help you 92 more times, we'll be even.
MRR is offline
