what if i hooked a switch up to the wire that goes from 2 to 13? could i turn them on and off?
09 Altima 2.5sl my new toy
red brick, black leather.
xp1000.1d crossfire amp
5 farad cap
custom red and black sub box.1 inch thick mdf
2 12 infinity refrence
Xentec hid's 8,000k
custom grounding kit
20% tint
headlight lid from bat
raceland remote controlled mufflers
Peripheral ipod interface
Hey, this is a question not regarding this situation, but still related to fog lights. (i didn't want to start another thread, and never really had my question answered). I had my fog lights installed by a aftermarket place about a year ago. He made it so I had a switch to turn the fog lights on and off, but they could be used even when the vehicle was not on. I didn't like this, because if I forgot to turn off the switch, it would drain my battery. Also, he made it so that my fogs would turn off when I high-beamed. I want it so that the fogs can only be used when the car is on, but can also be toggled on and off with the switch. I just moved the power wire from the battery and spliced it in with the parking lights, but am afraid this is putting too much of a load on the parking lights. Is there anyway to connect the power back to the battery, but still have the fogs work only when the car is on, or parking lights/lowbeams are on. Thankss
2007 Nissan Altima 3.5SE
Alpine CDA-9885 Stereo/Infiniti Amp/JL Audio Subwoofer Enclosure
35% tint all around
OEM Fog lights - installed
if youre running the power straight off the battery they will always be able to work with the car off. I would re-wire everything the right way. Im sure there is a write up on here for installing fog lights on a car that is not pre-wired maybe that will give you the answer you are looking for.
you'll want to move the foglight power back to the battery. what you want to do is move the Foglight Switch power cable to a "switched" source such as the front Cigarette lighter plug. this way, when the car is off, there is no power connection through the on/off switch (so the lights will be off). when the car is on, you can switch them on/off by flipping the switch.
to do this without putting strain on any other circut, you will want to have the lights powered off of the battery. remember, it's not the battery that turns them on/off but the switch inside the cabin that determines the on/off status so that's what you should have rewired.
~SB
__________________ 2009 Honda Fit Sport 2007 Frost White Altima 3.5SE: Sedan with Fogs & Wing. - AVG MPG: 26.41 @ 29,246mi Best tank 566Mi. (Traded @ 30K Miles)
Former/Current Cars: '86 Prelude Si. 2.0 | '93 Integra GS | '98 Civic EX | '00 Integra GS-R | '06 Ridgeline RTS | 07 Altima 3.5SE
It could be that the purpose of your life is only to serve as a warning to others.
hey thanks a lot specboy, thats exactly what I was looking for. I guess i didn't read deeply enough when I looked over gatorglaze's write-up, and am def. no wiring pro. Thanks again.
I'll bring this thread back to life with a question I have, couldn't seem to find the answer searching.
I believe my car is prewired for fogs. Now, theoretically, if I install fogs and plug them in will they turn on with the headlights (Since there is no switch)?
Do I still need to install a switch or is it completely optional?
the parking light has nothing to do with the fog light... do you mean daytime driving lights?? those also have nothing to do with fog lights.. install fog lights and hook them up to your low beams if you want to use the method that's used in this thread.
2008 2.5S Coupe Super Black purchased 07/15/08
