How to turn off the low tire pressure light? - Nissan Forums : Nissan Forum
post #1 of 4 Old 06-21-2012, 12:57 AM Thread Starter
I just bought this '08 coupe and even though all the tires are at 36psi, the warning light is on. I don't have an owners manual yet so how do you shut it off?
atikovi is offline
post #2 of 4 Old 06-21-2012, 01:07 AM
702L32's Avatar
Quoted: 1 Post(s)
iTrader: 5 reviews
it only shuts off if it reads the correct tire pressure from the sensors. if they are all at the right psi then a tire sensor may be bad. has happened to a lot of people in here so far. go here 2007-2012 Nissan Altima Forums - Nissan Forums : Nissan Forum and use the search and search for TPMS
702L32 is offline
post #3 of 4 Old 06-21-2012, 11:20 AM
Did you give it enough time to reset? Does the warning light flash first, or is it solid as soon as you start up?
~Mark
SOLD: 2010 Altima 3.5SR Coupe Fully Loaded- Eibach Springs/Racingline Y-Pipe/Takeda Intake
Nissan Factory Service Manuals (FSM):
http://www.nicoclub.com/FSM/
VQP0WER is offline
post #4 of 4 Old 06-21-2012, 12:13 PM
sentratech12's Avatar
if the light flashes repeatedly on start up, and then after about 15 seconds of flashing, goes solid...youve probably got a sensor problem. and need it checked/replaced.
LED dash underlighting, painted engine cover, painted battery cover
sentratech12 is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007-2012 Nissan Altima Forums > 2008+ Nissan Altima COUPE Discussion
