http://www.nissanclub.com/forums/new...cs-follow.html
Observe above post to find out your problem.
Once you ground the connector, keep it connected to ground. The TPMS will come on solid after five seconds and stay lit for 5 seconds, then it will go off for 5 seconds. THEN, it will start flashing out the error codes to you. The first digit is represented by the slow flashes, the second digit by the fast flashes. It will just keep repeating all the error codes as long as you keep the check connector grounded. Did you have your wheels replaced also, or just the tires?? If it was tires only, then you shouldn't be having this problem unless the shop goofed up one of your sensors.
Flickering pattern
Items Diagnostic items detected when··· Check item
15 Tire pressure value (Front LH) Front LH tire pressure drops to 181 kPa (1.8 kg/cm, 26 psi) or less.
16 Tire pressure value (Front RH) Front RH tire pressure drops to 181 kPa (1.8 kg/cm, 26 psi) or less.
17 Tire pressure value (Rear RH) Rear RH tire pressure drops to 181 kPa (1.8 kg/cm, 26 psi) or less.
18 Tire pressure value (Rear LH) Rear LH tire pressure drops to 181 kPa (1.8 kg/cm, 26 psi) or less.
21 Transmitter no data (Front LH) Data from front LH transmitter can not be received.
22 Transmitter no data (Front RH) Data from front RH transmitter can not be received.
23 Transmitter no data (Rear RH) Data from Rear RH transmitter can not be received.
24 Transmitter no data (Rear LH) Data from Rear LH transmitter can not be received.
31 - Transmitter checksum error (Front LH)
Checksum data from front LH transmitter is malfunctioning.
32 - Transmitter checksum error (Front RH)
Checksum data from front RH transmitter is malfunctioning.
33 - Transmitter checksum error (Rear RH)
Checksum data from rear RH transmitter is malfunctioning.
34 - Transmitter checksum error (Rear LH)
35 - Transmitter pressure data error (Front LH)
Air pressure data from front LH transmitter is malfunction.
36 - Transmitter pressure data error (Front RH)
Air pressure data from front RH transmitter is malfunction.
37 - Transmitter pressure data error (Rear RH)
Air pressure data from rear RH transmitter is malfunction.
38 - Transmitter pressure data error (Rear LH)
Air pressure data from rear LH transmitter is malfunction.
41 - Transmitter function code error (Front LH)
Function code data from front LH transmitter is malfunction.
42 - Transmitter function code error (Front RH)
Function code data from front RH transmitter is malfunction.
43 - Transmitter function code error (Rear RH)
Function code data from rear RH transmitter is malfunction.
44 - Transmitter function code error (Rear LH)
Function code data from rear LH transmitter is malfunction.
45 - Transmitter battery voltage low (Front LH)
Battery voltage of front LH transmitter drops.
46 - Transmitter battery voltage low (Front RH)
Battery voltage of front RH transmitter drops.
47 - Transmitter battery voltage low (Rear RH)
Battery voltage of rear RH transmitter drops.
48 - Transmitter battery voltage low (Rear LH)
Battery voltage of rear LH transmitter drops.
52 - Vehicle speed signal error Speed signal is not detected. WT-20
53 - BCM failure about TPMS Tire pressure monitoring system malfunction in BCM
Late,
Trav
