Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Discussion > *NEW* 2007+ Nissan Altima Discussion > 2008+ Nissan Altima Coupe
  #16 (permalink)
Old 05-08-2009, 02:11 PM
bina12834's Avatar
bleeds Black & Gold
Originally Posted by ddlatone View Post
i read in another post that there is an auto lock feature...if you leave your car and not lock it, it will lock automatically? i might have to try this out. would i lose this too? i just bought the car, so i guess losing that stuff is not a huge deal.
wow, what a noob i feel like...is there a quick disconnect on the battery? or do i need to remove a nut or something?
a little off topic...if anyone knows a lot about HIDs and installing them can you shoot me a pm? i am guessing the battery needs to be disconnected for this too right? i am thinking about doing this, but not too sure if i want to take the plunge.
if you have an '09 then you have the auto-lock feature, and i cant help you there. the easiest way to disconnect the battery is to remove the nut and take the connector off the terminal.
just do a search about HIDs.....theres 100s of threads about them in here.
2008 Super Black 2.5SL CVT w/ Connection and Technology packages, Xentec HID Super Slim Ballast 5000k lows and fogs, 3.5 side mirrors, K&N drop in filter
  #17 (permalink)
Old 05-08-2009, 02:27 PM
do i have to disconnect the battery? could i just make sure the lights are off at the time?
  #18 (permalink)
Old 05-08-2009, 02:28 PM
bina12834's Avatar
bleeds Black & Gold
its safer to disconnect the battery
  #19 (permalink)
Old 05-08-2009, 06:08 PM
Tonychanman's Avatar
Blackmobile
depends what lights you're trying to change. but i agree with bina, safer to disconnect, otherwise you risk blowing a fuse. if you're trying to change your dome, map and license plate lights, those can be changed since those lights can be turned off. but the door courtesey, vanity and trunk light are on if you want to try to change them.
and you definately want to disconnect your batter if you want to do an HID swap. and you shouldn't worry about doing it either, it's not hard. HID was my very fist mod, ever, on any car. there's lots of help and support on the forums if you run into any trouble.
2008 2.5S Coupe Super Black purchased 07/15/08
Debadged | White intererior & license plate LED's
20/35 Tint | DDM 6000k HID's | Autopia Fogs
Short Throw Shifter | Razo RA96 Shift Knob
Racingline Rear Sway Bar, Grounding Kit & Strut Bar
19" G35 Forged Ray's wrapped in Potenza RE050A
  #20 (permalink)
Old 05-08-2009, 06:15 PM
ideally i want to do the HID, but i am just worried about the warranty because i still have a lot left on it. i dont want them to give me any crap if i have a problem.
are the LED headlamps any good?
  #21 (permalink)
Old 05-08-2009, 06:38 PM
just an user
LED headlamps ? as in 'daytime running lights' .... or perhaps you mean low beam LED ?
Click !
  #22 (permalink)
Old 05-08-2009, 06:41 PM
yes, LED low beams. or if not, does anyone have other suggestions for headlight solutions? the stock ones BLOW.
  #23 (permalink)
Old 05-08-2009, 06:54 PM
Blackmobile
there are no LED low beams for our cars. if you're really worried, don't upgrade them. but like i said, if you want to get hid's and don't want to worry about warranty, then get a relay harness, it will take away any risk of any damage to your factory harness. the power will be drawn directly from you battery to your lights through the relay harness.
  #24 (permalink)
Old 05-08-2009, 06:59 PM
can you suggest a good set of HIDS with the harness? i found some on ebay for like $60 shipped. this about right? i guess i could just put the old ones in there if i need to take it in and none will be the wiser.
  #25 (permalink)
Old 05-08-2009, 08:31 PM
Blackmobile
if the seller is supervtec then yes, those are a good set to buy. a lot of members have those hid's. i have a set from DDMtuning.com because their sets come with a lifetime warranty. also pick yourself up a wiring harness, here's the link for both:
HID kit: DDM 35W & 55W Slim Ballast HID Kit: DDM Tuning - HID Kits, HID Bulbs, DEPO Lighting, BMW and Porsche Performance Accessories
harness: HID Accessory Harness (Assy): DDM Tuning - HID Kits, HID Bulbs, DEPO Lighting, BMW and Porsche Performance Accessories
edit: beware with one issue with ddmtuning kits though, read this post and you'll see http://www.nissanclub.com/forums/new...dm-tuning.html
  #26 (permalink)
Old 05-08-2009, 08:42 PM
can these headlights be re focused slightly downward so i dont get flashed all the time?
  #27 (permalink)
Old 05-08-2009, 08:51 PM
can someone help me with the bulb type? H1?
eBay Motors: JDM Nissan Armada Altima 99- 04 05 06 07 08 09 HID Kit (item 280321396535 end time May-08-09 19:11:18 PDT)
so this does come with the harness correct?
  #28 (permalink)
Old 05-08-2009, 09:13 PM
Blackmobile
H11 for coupe headlights. and the link you gave does not have a relay harness, that's only the harness used to plug into the factory harness. you want to buy a sepearte relay harness which will connect to the battery. something like this: eBay Motors: HID Fuse Relay Harness Wire Nissan 9003 9005 9004 H11 (item 380121566381 end time May-08-09 18:00:57 PDT)
  #29 (permalink)
Old 05-08-2009, 09:20 PM
i have a sedan, is that H1?
NM, i found it. sedan is H11 too. might be making a purchase tonight...
  #30 (permalink)
Old 05-19-2009, 03:21 PM
1998AltimaDan's Avatar
back on topic... lol
I did the whole V-LED thing (even got V-HID bulbs for my DDM kit) and i got the 194 5LED bulbs, and i was in the drive in the other night and realised that my car was off, but my dome/map/and door sill lights were very very dimly illuminated. i shut the power off to my map lights, and dome, but obv cant to the door sills. are any of u guys havin this problem too?? and what should I do if its constantly on/drawing power?
-Daniel
NEW 2008 Altima coupe 2.5s 6spd-Radiant Silver w/ convenience package
-Weapon R WAI
-Nismo Catback Exhaust
-RacingLine STS
-LED Tails
-Bat's Taillight overlays 6/10 full smoke
-35% doors/20% sills,rear tints/5% rear WS
-Kicker L5/1k watt amp/1farad Cap
1998 Altima GLE-Gone
-Spyder Front and side body kit
-Extreme Rear bumper
-2 10in Kicker CV 550watt subs
-Injen intake
-Altezza Diamond Black Headlights
-Altezza Black Tail lights
+ more.... Goodbye old friend
