Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Discussion > *NEW* 2007+ Nissan Altima Discussion > 2008+ Nissan Altima Coupe
Old 05-04-2009, 06:13 AM
Tonychanman's Avatar
Blackmobile
How To: Install LED lights
So since nobody's ever made a write up, and there seems to be a question about it every week, i figured i'd do a write up for everyone.
Materials needed:
1) Flat head screwdriver or butter knife
2) LED's: I used LED's from V-leds.com:
5xSMT LED's for the 194's: http://www.v-leds.com/Exterior....html
I only used 4x LED bulb for the license plate lights, but many people reccommend these: http://www.v-leds.com/Exterior....html
*Edit: trunk light is also 1x 194 bulb
16xsmt LED for the rear dome light: http://www.v-leds.com/Interior....html
*Note: this dome light only applies to the coupes. sedans have 2 more 194 bulbs over each rear door.
Vanity led lights: http://www.v-leds.com/Interior....html
I used a butter knife, since for some of the covers, the slot to get into is so small that a screwdriver wouldn't fit. A butter knife is also smooth enough to not leave any scuff marks on the surrounding plastic.
First of all you'll want to disconnect the battery or you risk blowing a fuse.
Remember that most of these lights are polarized, so when you put them in, don't replace the covers until you've reconnected the battery and tested out each light and if they don't light up, then pull them out and turn them around.
First for the map lights:
Instert the butter knife under the map light cover, then pry the cover off to expose the bulb inside, just pull out the old bulb and put in your 194 size LED
For the rear dome lights:
Same as the maps, insert your butter knife under the cover, pry it open and pull off the cover, then pull out the old bulb and throw in your 3022 LED. this bulb might be hard to pull out with your fingers, so just slip the butter knife behind the bulb and gentrly pry it out.
Courtesy door lights:
For these, you don't even need a screwdriver or knife. Just put your fingers underneath the cover and pry them towards the front with your fingers. These are tricky to get into since they have a casing around them. Again pull out the old one and insert the new 194 LED.
Visor lights:
Stick the butter knife into the bottom of the light cover, you'll see a small knotch where you can stick it into. apply some pressure and the cover will bulge out, allowing you to pull it off. These bulbs are hard to pull out, so as you did with the dome light, stick the butter knife behind the bulb and gently pry it out. now, these led's are polarized, so you have to put them in the right way. if you look at the reverse of the LED bulb, you'll see a small metal piece, this should be at the bottom when you instert the LED. And make sure that when you insert these, that the LED's face outwards.
2008 2.5S Coupe Super Black purchased 07/15/08
Debadged | White intererior & license plate LED's
20/35 Tint | DDM 6000k HID's | Autopia Fogs
Short Throw Shifter | Razo RA96 Shift Knob
Racingline Rear Sway Bar, Grounding Kit & Strut Bar
19" G35 Forged Ray's wrapped in Potenza RE050A
Old 05-04-2009, 06:14 AM
Blackmobile
License plate lights:
Open the trunk and remove the clips. Stick the butter knife in between the center cap and the outer ring. Prop it out and it will pop out halfway, then pull out the entire clip. Do this for half of the carpetting until you can acess the license plate bulb assembly. Be careful of the escape latch, the carpeting needs to be maneuvered around it to make sure you don't break the latch. When you seperate the carpeting form the trunk, you'll see 2 grey bulb assemblies. Turn each one counter clockwise one quarter turn and they'll come out. Replace the halogen bulb with the LED bulb and you're set! Again, don't forget to test the bulbs before you put them back in.
now put on your shades and enjoy the light!
The following is a comparison pic of 1xled bulb compared to the 5xSMT LED bulb
Old 05-04-2009, 07:49 AM
just an user
THANK YOU very much
you helped me install all my LEDs
Click !
Old 05-04-2009, 02:34 PM
1998AltimaDan's Avatar
the front map lights, the push ones- what size is that/LED bulb? it looks like u used the 16 in the front and bak? or is it the same?
then the door courtesy door lights- are those ... which ones? lol
-Daniel
NEW 2008 Altima coupe 2.5s 6spd-Radiant Silver w/ convenience package
-Weapon R WAI
-Nismo Catback Exhaust
-RacingLine STS
-LED Tails
-Bat's Taillight overlays 6/10 full smoke
-35% doors/20% sills,rear tints/5% rear WS
-Kicker L5/1k watt amp/1farad Cap
1998 Altima GLE-Gone
-Spyder Front and side body kit
-Extreme Rear bumper
-2 10in Kicker CV 550watt subs
-Injen intake
-Altezza Diamond Black Headlights
-Altezza Black Tail lights
+ more.... Goodbye old friend
bina12834's Avatar
bleeds Black & Gold
hey can you get a better pic of how you have your ipod mounted?
2008 Super Black 2.5SL CVT w/ Connection and Technology packages, Xentec HID Super Slim Ballast 5000k lows and fogs, 3.5 side mirrors, K&N drop in filter
Old 05-04-2009, 03:29 PM
wow- nvm- i just opened em up lol ty for the writeup
Old 05-04-2009, 04:34 PM
v-led's website is pissin me off i have 5 things ordered along w/ my d2s bulbs and i cant f'n go threw the checkout cus it keeps rerouting me back to the first page XD >
Old 05-04-2009, 08:05 PM
Nice job. Once this thread dies down, I'll add it to the FAQ Forum if you'd like.
3.5SE M/T
Old 05-04-2009, 09:14 PM
+1..it looks clean..
2008 Super Black 2.5SL Altima Sedan
15% Around, 35% Windshield, OEM HID, OEM Foglights, Interior & License Plate LEDs, 3.5 Side Mirrors, OEM Style Spoiler, Redout Tail Lights, Clear Bra, Aluminium Kick Plates, Dynamat/B-Quiet (Doors, Rear Deck, Trunk and Floor), Hoodliner, iPod Interface, SBD Grounding Kit, Stillen RSB, Racingline F/R Endlinks and Strutbar, 18" SSR GT3 wrapped in Toyo Proxy 4, Black Muteki Lug Nuts
Old 05-04-2009, 10:28 PM
Blackmobile
thanks guys, just let me know if i forgot anything
Old 05-05-2009, 03:25 AM
Nickblitz40's Avatar
nice write-up. ill definitely be using this later on
08 Coupe 2.5 CVT
Eibach Pro Kit||HPS Intake||Nismo Exhaust||Debadged||25% tint||DRIFz Rims||Stillen Front Lip
Old 05-05-2009, 01:50 PM
bina12834's Avatar
bleeds Black & Gold
Old 05-08-2009, 01:52 PM
does disconnecting the battery mess anything up? like resetting miles/service things?
Old 05-08-2009, 02:02 PM
bina12834's Avatar
bleeds Black & Gold
you have to reset your auto-up windows, you lose your radio stations, the MPG/Range/other stuff are reset, but im not sure about the service warnings because i never had those programed.
Old 05-08-2009, 02:07 PM
i read in another post that there is an auto lock feature...if you leave your car and not lock it, it will lock automatically? i might have to try this out. would i lose this too? i just bought the car, so i guess losing that stuff is not a huge deal.
wow, what a noob i feel like...is there a quick disconnect on the battery? or do i need to remove a nut or something?
a little off topic...if anyone knows a lot about HIDs and installing them can you shoot me a pm? i am guessing the battery needs to be disconnected for this too right? i am thinking about doing this, but not too sure if i want to take the plunge.
