Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN ALTIMA FORUMS > 2007+ Nissan Altima Discussion > *NEW* 2007+ Nissan Altima Discussion > 2008+ Nissan Altima Coupe
Old 05-22-2009, 04:15 PM
Mass Air Flow Sensor Code
I have a 2004 3.5 Alt.
I took the air cleaner housing out to change the bulb in my front head light and after everything was put back together, the check engine light came on. I disconnected the negative battery post for 30 minutes, and drove 200 miles and the light is still on. I went to get the code and it is saying Mass Air Flow Sensor.
I check to make sure everything was hooked back up and nothing is out of place. I also change the air filter while I had it apart. Does anyone have any ideas of what I may have done to make this code or anything I can do to make it go away?
Thanks
Old 05-22-2009, 08:05 PM
white6spd's Avatar
Look inside the plug, make sure nothing is missing or broke. Check for any moisture, make sure its plugged in the right way, and if all else fails bring her back to Nissan, dont mess around to long MAF sensor's are pretty expensive
Stillen Cat-Back(No Resonater)
Stillen Front+Rear Slotted Rotors
Stillen Front Strut Bar
Stillen Rear Sway Bar
Stillen Hood Damper
Stillen Grounding Kit
RacingLine Y-Pipe
RacingLine EndLinks Front+Rear
BullyDog GT Tuner
AEM CAI
RacingLine STS
Metal Matrix Front+Rear Pads
Goodridge SS Brake Lines Front+Rear
Tinted Windows
PIAA Ion Crystal Fog Lights
8000K HID's
LED's
245/45/18 Tires on 18in O.Z Wheels
Old 05-22-2009, 08:45 PM
scrutmonkey's Avatar
Fatty McFat fat
you just need to use the SES procedure and after reading the code, step on the gas and hold for 10 seconds (or around that much time).
'08 Slate Hybrid w/ tech package: RL endlinks - F/R, RL STB, Stillen RSB, Stillen hood dampers, Fujita SRI, LED's everywhere, DDM 35w 6k HIDs, OEM fogs w/ Hoen XMP, & digital touch switch, Switchback LED mod, 35% 3M tint all around, Bat style eyelids - 6/10 x 2, KP mirror tilt mod, debadged w/ Decepticon.
Originally Posted by 07 Winterfrost 3.5 SE View Post
These are super gay!
