Originally Posted by GKG
I just purchased steel wheels for winter use on my 09 coupe and 4 tpms from the dealer. I had to purchase the nuts separately and the parts person also sold me 4 grommets which he said are for the nuts. I checked out my service manual and it makes no mention of a grommet being installed with the nut, the only grommet is on the sensor stem itself and it comes with the sensor. So does the nut need this grommet or do I just install the nut and be done with it?
Thanks,
Gary
Just my 2 cents but why would you go through that hassle? Just run your steel rims without the sensors, check you pressure regularly as in the winter, the tpms tend to set off the dash light quite a bit. The light on the dash is a good reminder to check your pressure at each fill up or each month etc.
Go get some money back.
'07 Ebony 2.5 s with cvt and convenience/ 35%f 20%r tint /18" 350z touring rims/magnaflow 14829's/4300k HID, Fujita SRI
'06 Xterra SE Night Armor full load: the wife's
