2013 Altima head lights - Nissan Forums : Nissan Forum
post #1 of 67 Old 01-17-2013, 11:34 PM Thread Starter
Quoted: 4 Post(s)
I was looking in the owner manual and they came with Halogen and Xenon light bulbs how can I till which one I have and if so does it matter if I put sylvania silver star zxe halogen bulbs in.
d cleve is offline
post #2 of 67 Old 01-18-2013, 12:17 AM
2013 Altima 2.5SL w/ Tech
NVNJ's Avatar
Xenon = HID I believe.
What's involved with changeing the headlight bulbs to sylvania?
NVNJ is offline
post #3 of 67 Old 01-18-2013, 01:08 AM
Dweezil's Avatar
d_cleve, which 2013 Altima did you get? 2.5? 3.5? SV, SL...?? To my knowledge, the only trim level that comes with HID lights is the 3.5 SL. All other models are standard halogen bulbs.
*EDIT*
But one can easily convert their car to HID lights for approximately $100. I did, and it made a huge difference in improved visibility.
2013 Altima 2.5 SL w/Tech. Pkg. Silver
Dweezil is offline
The Following User Says Thank You to Dweezil For This Useful Post:
post #4 of 67 Old 01-18-2013, 02:15 AM Thread Starter
Quoted: 4 Post(s)
It is a 2.5 SV
*EDIT*
but when I was putting my fog lights in it looked like a ballast was wired in, there not white head lights for sure thats why I'm changing them I wil go with HID's later on but was wanting to wait for a bit.
d cleve is offline
post #5 of 67 Old 01-18-2013, 03:41 AM
2013 Altima 3.5SL w/ Tech
AltimaMRI's Avatar
Yup, only the 3.5SL has HID.
-Bob
AltimaMRI is offline
post #6 of 67 Old 01-18-2013, 03:08 PM
Rob0381's Avatar
Installed a set of Silverstar ZXE's in my headlights last night. The difference is a huge improvement over stock. No more yellow light, and much brighter. They arent as bright as HID's, but they do have a look of an HID, clean white light and just a hint of blue around the edges of the beam. Ill be putting another set in the foglights next week.
2013 Altima 3.5 SV Brilliant Silver
Rob0381 is offline
post #7 of 67 Old 01-18-2013, 03:22 PM
flipn0tic's Avatar
Quoted: 1 Post(s)
Got pics?
2013 Altima 2.5 SV
Added: 5000k HID lows; LEDs for license plate, doors, and courtesy lights; Weathertech mats; footwell lighting kit
To-Do list: HID fogs; 30% window tints; LED for glovebox light; debadge trunk; plastidip front and rear chrome trim; smoke tail lights
flipn0tic is offline
post #8 of 67 Old 01-18-2013, 03:33 PM
Warranty?
I know it sounds a bit paranoid but any thoughts on whether this invalidates factory warranty? I'm guessing if I ask the dealer service dept. they will say don't do it. I like SilverStar bulbs.
Jay
jaymegruen is offline
post #9 of 67 Old 01-18-2013, 03:52 PM
flipn0tic's Avatar
Quoted: 1 Post(s)
Jay
Changing your headlight bulb won't void your warranty.
If there is any kind of failure or damage that can be traced back to a mod, then maybe. But a simple bulb replacement? I'd say you're safe.
I saw this little excerpt on edmunds:
The saving grace for consumers is the Magnuson-Moss Warranty Act of 1975. The act states that a dealer must prove that aftermarket equipment caused the need for repairs before it can deny warranty coverage.
However, if the reason for a parts failure is unclear, a dealer will usually charge you to diagnose the vehicle. If the aftermarket part was not properly installed or a modification led to a component failure, it is within the dealer's right to void the warranty for that part, and you will have to pay for the repairs out of pocket. If the aftermarket parts had nothing to do with the repairs in question, you will be refunded the fee for the diagnosis.
2013 Altima 2.5 SV
post #10 of 67 Old 01-18-2013, 04:01 PM
Before and After - Makes a huge difference! Def a cleaner look! I also swapped out my fog lights.
Click image for larger version
RMAHER07 is offline
post #11 of 67 Old 01-18-2013, 05:33 PM
NVNJ's Avatar
Is that HID or Sylvania?
NVNJ is offline
post #12 of 67 Old 01-18-2013, 05:44 PM Thread Starter
Quoted: 4 Post(s)
Which of the H11 silverstar did you use ultra high performance or just the high performance and will the H11 be ok in the fog lights the same bulb you use for the low beam?
d cleve is offline
post #13 of 67 Old 01-18-2013, 05:50 PM
NVNJ's Avatar
It's sucks that we can't access the headlight bulbs from the hood. Turn the wheel. Remove clips etc is silly.
NVNJ is offline
post #14 of 67 Old 01-18-2013, 06:01 PM
flipn0tic's Avatar
Quoted: 1 Post(s)
The fog lights are the same bulb type as the lows (as well as highs).
2013 Altima 2.5 SV
post #15 of 67 Old 01-18-2013, 06:44 PM
HID 4300k I believe
RMAHER07 is offline
