Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B13 1991-94 Nissan Sentra Discussion
Old 03-28-2009, 06:04 PM
clutch and throw out bearing
hey,
i have just put a new clutch in my 91 nissan sentra, but when i put the transaxle back in the clutch wont work and the pedal just goes right to the floor, i have had it in and out about 3 times now, the throw out bearing is staying in place and everything, but still the clutch wont work, when i put it in i didnt have the alignment tool so if the clutch is a littel off centered could that be the problem? or any other suggestions? thanks
Old 04-07-2009, 11:42 PM
MercerSX's Avatar
its your clutch cable, buy a new one if you can't tighten it anymore
but really you SHOULD use an alignment tool next time! good luck
92 se-r
95 ex
06 sv650
Old 04-10-2009, 12:59 AM
yea thats what i thought to, but when the transaxle is all in an i just pull on the lever that goes inside and pushes the throw out bearing it will go in all the way, but wont return, i have to pull it back by hand, and it doesnt take any effort to push it in or pull it out
Old 04-12-2009, 05:30 AM
MercerSX's Avatar
sounds like the spring came off inside, sorry but you will probably have to pull it back out and make sure that spring is returning the lever back before you put it back on
Old 04-12-2009, 03:40 PM
i do have it out, and the springs seems to be fine, i have no idea what it could be i feel like i have gone over everything, if i was givin the wrong clutch could that be why?
Old 04-12-2009, 04:07 PM
kasey07's Avatar
shift_wheel hop
are you a hydrolic set up or cable? if hydro did you bleed the system? sounds like a slave cylinder problem tho to me
Old 04-12-2009, 05:15 PM
MercerSX's Avatar
should be cable.. is this a 1.6l or the 2.0l se-r? maybe some pictures might help.
if the spring is properly in place then it should be returning the fork lever..
sorry i cant really think of anything without seeing what your working with here
Old 04-12-2009, 08:46 PM
yea, well ill take a look at the spring once more and see if its in there properly, and check, maybe its broekn and i cant see that it is, and if not then ill take some pictures and post them
