acceleration problem - Nissan Forums : Nissan Forum
post #1 of 4 Old 05-14-2008, 01:15 AM Thread Starter
my 1996 200sx se-r seems to accelerate fine at lower RPMs. When i really give it throttle it seems to bog down quite a bit. possible fuel pump issue? The engine revs fine at high RPMs in neutral. as soon as i let the clutch out and really give it gas it seems like that is when the problem occurs. Anyone experience the same problem?
200sxSER1996 is offline
post #2 of 4 Old 05-31-2008, 05:10 PM
Don't tickle the Dragon
mountnman's Avatar
where are you cutting off "low" rpm? 2000? 3000?
and it throttles up at low rpm, and in neutral.. is that under load at low rpm? or just a slow steady acceleration? what does it do at higher rpm's when your not "really giving it trottle"?
most of the time, what i consider "bogging down" is caused by not enough spark or air, fuel is usually too much for the mixture...
at first blush i would say you need a complete tune up with new plugs and wires, and i might get that car "tuned" to make sure your spark is mapped right... possible slippage on the timing.. something else to check
Drive safe and play nice.
mountnman is offline
post #3 of 4 Old 06-01-2008, 06:13 PM
VTEC wont save you....
bogging or slipping...check your plugs wires first...no CEL's?
BWAHAHAHAHAHAHAHHAHAH
HondaKillah is offline
post #4 of 4 Old 06-28-2008, 07:59 PM
I have a 95 200sx SE-R, I have a similar problem, where the vehicle in low gear IE first up to third is great, acceleration is decent however when I am using either cruise control while I am in 5th gear going 65 or higher I seem to be keeping a consistant 3500 rpm to 4000 depending on the speed. I know I have to replace my clutch soon but is there anything else that I should look at?
kucolan is offline
  Nissan Forums : Nissan Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B14 1995-1999 Nissan Sentra & 200SX Discussion
