Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B14 1995-99 Nissan Sentra & 200SX Discussion
Old 12-31-2008, 01:36 AM
95 200sx cranks but doesnt start
i am working on my sisters 95 200sx it cranks but does not start. i have injector pulse on all cylinders with noid lights they are good. i have spark but in my opinion weak and not consistent. i have checked for jumped timing chain all appears to be ok. i have a code p1320 for primary ignition. on alldata it says to test power transistor to measure resistance between two pins. it tested bad. it had no continuity. so i got a used distributor and it also had no continuity. is there another way to test this or id i just get a bad one?
if anyone has any ideas or help would be appreciated.
Old 12-31-2008, 03:54 AM
InfinitIdiot's Avatar
Ludicrous Skills
Can you show me a pic of where you tested? I can check my known good one and verify this is correct.
John
[SIGPIC]
Old 12-31-2008, 04:59 AM
http://s203.photobucket.com/albums/a...t=62480911.gif
Old 12-31-2008, 10:59 PM
HondaKillah's Avatar
VTEC wont save you....
Was it an OEM dist?
Why buy a used one,IIRC a new cap and rotor were only like $30 bucks from the dealer.
Nissans are kinda finicky when it comes to OEM electrical parts,alts,dist,wires,plugs,etc...
1999 Platinum Gold Nissan Sentra SE-L Manual
JWT ECU+JWT Popcharger+SSAC Header+Ksports Coilovers+16X7" Sportmaxx 002
2002 Aspen White Pearl Infiniti G20 Manual
Old 01-02-2009, 06:08 AM
Ludicrous Skills
I went out tonight and checked the wiring on the connectors. I also had no continuity. i made sure to check the index marks on the connectors and I am VERY competent with a DVM. I then plugged the connectors back in and fired up the engine just as a sanity check that it will be ready to go in the morning. I don't know what to tell ya!
John
