1st mistake was going to Firestone to have engine work done ... 2nd is believing anything they say !!
I would bet you dont have any leakage from the oil pan ... VERY rare on a Nissan ... Your leak is the front crank seal , VERY common on Nissans ...
Crank seal is fairly easy , pull the belts , remove the front crank bolt ( thats the hard part , may take air tools to do or some tricks ... are you auto. or 5 speed ? ) ..then pull the crank pulley off , remove old seal , tap new seal in with hammer , lube seal with oil and replace a torque everything !! Replace the belts with new !!
We get the old " your oil pan is leaking " all the time from lube shops ... If you get any leakage from a seal or even just from doing oil changes and the oil filter leaking down , the oil will build up on the pan rails and make its way around the pan , looks like an oil pan gasket leak ... but very rarely is !!
Oh yea, front crank seal replacement on a '95 Sentra is 1.5 Hours ... so with belts its about $200 .... No idea where they are coming up with $1000 .... Thats just NUTS !!
SHAWN
Ger-Brock & Co. Portland OR.
Japanese import performance and repair .
'98 Forester L Driver/Corner carver
'06 Pathfinder SE
'99 Sentra SE-L For Sale
'98 Sentra SE Time Attack Car
'93 Altima SE 5 spd. (SOLD)
13.97 @ 97 MPH ... All Motor !!
My Nissan Site !!
