Go Back   Nissan Forums: Nissan Enthusiast Forum > Nissanclub.com Nissan - Infiniti Enthusiast Forums > NISSAN SENTRA / 200SX / SE-R FORUMS > B15 2000-2006 Nissan Sentra Discussion (SE-R / Spec-V)
Old 06-09-2009, 03:24 AM
little diagnosis help needed please
got 2 codes out of my buddys car
p0335 - camshaft position sensor a
p1615 - nissan specific code.........
pretty sure the first one is the cam sensor, ive read the second one has to do with disabling the starting of the car and he also has the issue of sometimes the car just cranks and doesnt start. what do you guys think of it
Originally Posted by The Almighty
May you not shake enough and dribble piss on the leg of your pants at some point today.
2004 40th anni mustang gt
1993 vw corrado
Old 06-12-2009, 06:02 AM
ok.. i dont know mutch about codes.. but for the starting problem.. Have your buddy try turning the key / ignittion to the 'on' position.. waitign 3 - 4 seconds, then trying to crank the car. Ive got a 2003 Sentra and work with auto-tech's all day, though im not one myself. I had that 'whont start' problem a few times and asked them about it as i knew it wasnt the battery. And one of the tech's mentioned that some Nissan's were bad for haveing their fuel pump system 'deprime' when turned off... Meaning there wouldnt be any fuel in the lines after the car had been turned off for a few minuts.. all the fuel would backflow back into the tank, and that letting it sit at 'on' for a few seconds gives the pump time to re-prime the lines. Turning the key to 'on'.. counting to 3 or 4.. then cranking the car works every time for me.
Old 07-04-2009, 05:18 AM
the suggestion above didnt seem to help, i replaced the cam sensor and the light came back on, anyone else got suggestions
Old 07-14-2009, 05:34 PM
Dread1's Avatar
try puttign back in the old cam phase sensor and swap out the crank sensor instead.
2003 Sentra Spec-v- This and that with a
Procharger 8.9 psi
