2004 Nissan 1.8 wont start - Nissan Forums : Nissan Forum
Old 02-13-2010, 01:15 AM
I Have a 2004 Nissan 1.8L and it wont start. it is currently tripping the code for the fuel level sensor. the car turns over fine but then sputters but wont start let me know if you guys have any ideas on what it could be
Old 02-17-2010, 10:10 PM
boyrs's Avatar
clogged fuel filter or fuel line? maybe air in the line can cause sensor to misread... does your fuel pump make noise when you turn on car(not cranking)? or if you're parked on sharp incline, the gas might be to low to be pumped and it's just sputtering off fumes...
Old 02-26-2010, 02:14 PM
SpecNmyI 02' SeSER SPec V
Is it possible that the fuel level sensor sending unit that is attached to the fuel pump is malfunctioning and needs to be replaced? You should be able to access it by first releasing the fuel pressure and then removing the back seat (at least that's how it is on my 2.5 spec v.) I would try to look at a service manual first to see how the 1.8 is laid out.
