Fuel Pressure Test on 02' Spec V - Nissan Forums : Nissan Forum
Old 02-26-2010, 02:10 PM
SpecNmyI 02' SeSER SPec V
I'm looking to buy the quick connector release tool to hook up a pressure gauge for a fuel pressure test. I don't want to buy it from the dealer and wanted to know if anyone knows what size tool I need. I think it is 5/16" but wanted to verify... also is there a specific adapter that I will also need. Thanks for any advice.
Old 08-27-2012, 06:27 PM
I found a part while searching google for just such a tool.
Part number is J-44321-6
I think it is for a Titan, but hopefully someone can clarify, because not only do we want the right part, that dang thing is $50
So What is need here is some way to get a "female" quick connection to make a fuel pressure check hose.
However it just dawned on me ...
2.5 Altima (not sure about sentra) has a fairly short line from the firewall to the fuel rail connection. I had a rubber hose and hose clamp on the male end of the firewall line when I was trying to fiddle with the quick connect. Rather than trying to connect to the quick connect, pull the whole line and use another rubber hose and hose clamp with the t fitting in the middle.
Not as cool as this http://www.nissanclub.com/forums/200...ml#post4123334 but will get the job done.
Be sure to use fuel line rated for fuel injection pressures.
