serpentine belt....need help!!! - Nissan Forums : Nissan Forum
Old 05-28-2010, 12:05 AM
Hi everyone,
I'm new here and was looking for help or a guide on how to change a serpentine belt. I was trying to avoid playing the dealer $179.00 to do it.
Any help would be appreciated!
BTW, I did a search and nothing came up.
Old 05-28-2010, 10:30 AM
boyrs's Avatar
http://www.nicoclub.com/FSM/Sentra/2002/em.pdf
page 89 has the diagram for the belt on the 2.5, if you have the 1.8, it should still be there but on different page.
on 2.5 it is taken off the with the auto tensioner. you put a wrench on it (long handle so its easy to torque) and you 'tighten it' and when you turn it as far as you can (which is only around 1/4 turn on the tensioner overall), there are two holes that line up and you can stick something through to lock the tensioner down- i use an allen wrench.
it's all in the FSM i linked above as well, but worded different.
Old 05-29-2010, 12:33 AM
thanks, i'll check it out!
Old 06-03-2010, 03:59 AM
ouch
I was quoted 145 for both the serpent and the power belt at the dealership. Even though I know a good trusted mechanic atleast mine charges like 50 bucks on average for any of our cars. So is the 1.8 an uncommon engine for this year?
Nissan Altima 2000 gxe (manual)
AEM WAI (short ram)
Strut bar
Modded VTC synalloid
Full ecm tune up programmed
Painted the valve cover and some other parts
Wire tucked.
current project:girlfriend restricted >.<
current repair: mystery check engine light(havent had a chance to run code..thought it was the temp sensor I put in *sighs* another problem....)
Nissa Sentra 2003 GXE (q18 went to the heavens...sr20det swapped)
Full custom fab exhaust.
Turbonetics 6085 (at 20 psi)
Forged street pro piston
Street pro (stage 5= cams)
Street Pro stage 3 clutch (she grinding alittle into 3rd)
New special computer (gonna tune after turbo still been doing motor work)
strut bar
Custom fabricated pod WAI, breather Intake.
New Fuel pump/fuel cell(buddy wont tell me what he used)
17's rims
lowering springs
Swaybar bushings
High performance camber/caster kit.(custom fab)
JDM Smoked headlights
8k blue HID's (xenon high/low)
432 HP to the wheels (before boost)
*priceless*
Current project:
Current repair: Still trying to figure out how to install tach gauge. Paint Job. Finishing install of header and permanately attaching turbo. Still need to re-tune after we complete the turbo as a permanate fixture, he had to custom weld and build a header running 4-2 sense the boost wasnt working right on 4-1, will post final WHP when Hondata runs the dyno again.
Old 06-04-2010, 12:08 AM
boyrs's Avatar
don't quote me, but i think around 80% of the sentras have the 1.8L
as far as i know, only the se-r, se-r spec v, and certain special editions have the 2.5L, i think there was a 2.0 on some as well but not sure what years...
Old 06-06-2010, 12:16 AM
Stitch's Avatar
Nissan Techy
00-01 SE sentras had the sr20.
Modifications/Upgrades:
Megan Racing header, Magnaflow Catback, JWT BSR, BG Synchroshift II, RevAuto Torque Dampner and Mobil 1 Full Synthetic, Painted Engine Cover
