Power window trouble - Nissan Forums : Nissan Forum
Old 07-11-2010, 12:46 PM
Hello
HELP PLEASE!
I have a 2002 Sentra and yesterday my driver side window decided to quit working. The window is stuck in the open position not sure if its the switch or the motor. I opened up the side panel and I noticed that when I push the window switch down I can hear the motor clicking. I'm kinda short on cash right now to replace anything. Is there a way to manually roll up my window? I have to go to work on Monday and the place where I park is not the safest.
thanks
Old 07-12-2010, 09:26 PM
Try one of two things. Take some WD40 and spray the hell out of the regulator, being sure to lube up the tracks, rollers, and pulleys. Then hit the window switch again and see if that helps. If that doesn't work, try helping the window up with your hand while pressing the switch in the up position. Sounds like something is binding and until you can figure out what it is, keep the window up until you have the cash to fix it.
