have you inspected the linkage, tested the outside and inside handle and greased the latch?
http://www.nicoclub.com/FSM/Sentra/2002/bl.pdf pg 32 for door diagram
junkyard would probably be the best, a pull-a-part type would give you practice in removing it if you have one in the area.
I have tested the inside and outside and find that the outside works. The inside works when I pull really hard and have taken a look at the latch action and found that it isn't engaging the way that it should be.
I have not take anything apart because, honestly, I am like a bull in a china shop when it comes to trim work.
Thanks for the link. I actually went to a U Pull It yesterday looking for some steelies and seen that there was only 1 B15 on the entire yard. Luckily there are 4 to 5 more places I can go to in a 50 mile radius.
Anything that I need to know to lube the latch? Is that an internal thing or can it be done from the outside with some lithium grease?
