first thing would be to pull radio out and make sure none of the pins on the jack are bent or missing, be sure to check the plug as well to see if any pins are still in it. also check to make sure there isn't a fuse directly on the radio. don't think there is, but it's been a long time since I pulled it out....
the amp and sub were on an audio upgrade package, might have not been in the car unless the owner told you otherwise.
