2005 SPEC V choking with low RPM in gear
Hello,
I have a problem with my 2005 Spec v 2.5. I changed all ignition coils and spark plugs, but it seems like every time I push pedal to the floor on 2nd or 3rd gear my car chokes until RPM is higher than 3000. There is no check engine light on.
Car is fine while idling, it is fine if I press gas pedal slowly, but when I do it fast it jumps back and forth several times until RPM is higher. This really worries me! There is only 80K on the engine and car mostly sits in the garage.
Any help or advice would be appreciated. I would rather go to mechanic knowing how much it is going to cost me rather than going clueless
Thank you
Jack
